ᐅ Ikea BESTA DIY: How do I install a countertop on Ikea BESTA?
Created on: 23 Feb 2021 10:07
naulen
I am currently planning to use my Ikea Besta furniture as a base for a worktop in my home office. I have a question: How can I build a stable and durable work surface on top of the Ikea BESTA units? Specifically, I am interested in aspects such as how to attach the worktop, recommendations for materials (for example, wood, MDF, stone-effect surfaces), and what to consider when cutting to achieve a clean, load-bearing result. It would also be helpful to know if certain accessories from Ikea or third-party suppliers are recommended to securely connect the worktop to the BESTA units.
I would greatly appreciate useful tips, personal experiences, and possibly step-by-step instructions to avoid common mistakes from the start.
moses
25 Feb 2021 08:06
I can understand how frustrating it is to do thorough research and still feel uncertain about the correct installation. I had a similar experience when I installed my countertop on Besta. What helped me was taking it step by step and not trying to get everything perfect all at once. One mistake I made was fixing the countertop too early before everything was properly aligned.
My little tip: first assemble everything loosely and check all measurements before securing it permanently. Patience really pays off with DIY projects. Also, if you have a surface that needs to be wiped regularly with a damp cloth, sealing it is definitely worth it; otherwise, you might regret it later.
naujon
25 Feb 2021 15:27
Gilbert schrieb:
Sure, that’s a classic. However, I would argue that simply screwing it down isn’t always enough.
A very good point! Additional supports, such as center beams under the panel, are especially recommended for larger work surfaces to prevent sagging. This can be done using simple wooden battens or metal profiles.
moses schrieb:
My little tip: Assemble everything roughly first and check the measurements before making anything permanent.
I can only agree. Dry fitting helps avoid mistakes during cutting and fastening. Especially when the panel has an overhanging edge, proper alignment is crucial.
Finally, a tip for edge finishing: If you get PVC edge banding, it can be neatly applied with a standard iron – this gives the panel a more professional look and makes it more resistant to moisture.
