ᐅ IKEA Besta DIY – How Do I Build a Unit with Removable Compartments?
Created on: 21 Nov 2018 18:24
Paudeo
Hello everyone, I want to build a combination based on the Ikea Besta system, where the individual compartments can be removed to adapt flexibly to different storage needs. Specifically, I’m interested in the best approach to design the compartments so that they are sturdy but can also be easily taken out and put back in at any time. What about suitable materials, the right dimensions, and connection mechanisms? Is it possible to repurpose the standard Besta elements for this, or are additional components recommended? I’m looking forward to your experiences and tips, especially on how you have ensured stability with frequent removal.
Paudeo schrieb:
How did you address stability when the compartments have only about 4-5 mm (0.16-0.20 inches) of clearance?In my experience, it is essential to edge-band the sides of the removable compartments with edge strips or aluminum profiles. This protects the cabinet edges from swelling and maintains their shape stability. For guidance, recessed tracks mounted on the sides of the frame help ensure lateral alignment. Another tip is to use self-adhesive felt pads on contact surfaces to reduce friction and prevent wear. This way, the construction remains durable even with regular use.
I really like the idea of removable compartments! 😄 Here’s another thought: if you want to make the compartments a bit lighter, you could use timber panels with perforated patterns instead of solid wood panels – this reduces weight and gives a modern look. And if you add color to the compartments, it really brings some character. This way, your Besta will not only be functional but also a real eye-catcher!
If you are combining different modules, I recommend creating a detailed plan beforehand that takes into account load and usage scenarios. This should include structural calculations to determine how heavily each component will be stressed. In the Besta system, combining shelving compartments with drawer mechanisms and removable inserts can be advisable to ensure both flexibility and stability. Be sure to use suitable accessories such as shelves with grid holes for flexible positioning.
fepau schrieb:
I installed small metal rollers that run along the sides, allowing the compartments to slide out easily.In my opinion, roller systems tend to be somewhat too vulnerable for long-term reliable use. The quality of the rollers and precise workmanship are crucial, but the level of stress is often underestimated. Solid rails are preferable, even if they don’t glide quite as smoothly. Stability is the most important factor here, especially when storing several kilograms (pounds) in the compartments.
