ᐅ How suitable is IKEA PLATSA as a wardrobe or coat storage solution?
Created on: 16 Aug 2022 08:37
Tarti
Tarti
16 Aug 2022 08:37
Hello everyone, I am currently considering replacing my existing wardrobe solution and have been thinking about using the IKEA PLATSA system for this purpose. My main question is: How well does IKEA PLATSA work as a wardrobe in terms of flexibility, storage capacity, stability, and appearance? I need a solution that can accommodate different types of wardrobe items – from coats and shoes to accessories – without appearing too bulky or unstable. Additionally, I am interested in how practical it is for everyday use, especially when it comes to quickly rearranging or adding modules. Has anyone had experience with PLATSA as a wardrobe, particularly with the specifically available wardrobe modules or corresponding interior fittings? Thanks in advance!
FeAndreas1
16 Aug 2022 09:18
Hello Tarti,
Your question fits perfectly with my experience, as I recently set up a PLATSA system as a wardrobe. Basically, PLATSA offers great flexibility thanks to its modular components. You can combine individual cabinets, open compartments, or closed boxes, which is especially practical for wardrobes.
Regarding stability: The basic structure is solid if assembled correctly, but for taller units, it is essential not to neglect wall mounting. A secure attachment to the wall ensures safety, especially when storing heavy coats or shoes.
As for storage capacity, PLATSA is versatile because there are various interior fittings—clothes rails, drawers, shelves—that you can combine freely. A downside is that for very large jackets or long coats, a sufficiently tall unit is recommended; otherwise, space can feel tight.
I would also like to know more about your spatial conditions so I can give more targeted advice on design and combinations. Are the dimensions rather limited, or do you have plenty of space? Are you looking for something that can be easily expanded later?
plopra
16 Aug 2022 09:42
PLATSA as a wardrobe is practical if you are looking for modularity. Securely attach it to the wall and choose models with a clothes rail or foldable shelves. Storage space is convenient, but depending on the size, you need to pay attention to the appropriate depth.
O
ODINFLO
16 Aug 2022 10:11
FeAndreas1 schrieb:
Regarding stability: The basic structure is solid when assembled correctly, but for taller units, securing them to the wall should never be overlooked.
This is a key point. I often see that the wall fastening is underestimated with PLATSA, which can be especially dangerous for wardrobes since the load varies. Additionally, I would add a question about the durability of the surfaces. For wardrobes, which are subject to heavy use, scratch resistance and ease of cleaning are important factors.
I also wonder: How easy is it to modify the unit? If someone wants to adjust or expand the wardrobe later on – how well does the PLATSA system handle that in your experience?
Tarti
16 Aug 2022 11:03
FeAndreas1 schrieb:
I would like to know more about your spatial conditions – so I can give more targeted advice regarding design and combinations. Are the dimensions limited, or do you have plenty of space? Are you also looking for something that can be easily expanded later?
Good question! My hallway is not very large, about 2.5 meters (8 feet) wide and 1.8 meters (6 feet) deep. I need something compact, but still offering enough storage for several jackets, shoes, as well as hats or scarves. I might expand it later, but only occasionally, perhaps by adding a module. The look should also be modern and not too dominant. Questions regarding the interior fittings: How well do the wardrobe rods and compartments offered by IKEA's PLATSA system handle heavy coats and larger shoes? And do the smooth-running drawers hold up well under frequent use?
NoValentin
16 Aug 2022 11:27
The coat rails are sturdy enough to hold heavy coats, but you should not exceed the maximum load capacity. The drawers glide smoothly on rollers and are suitable for everyday use. Shoes fit well in compartments, especially if you plan for several wide shelves.
