ᐅ What is the load-bearing capacity of the IKEA PLATSA shelves?
Created on: 12 Sep 2016 20:37
Ixmu68
Ixmu68
12 Sep 2016 20:37
I am currently looking into how much load the shelves of the IKEA Platsa system can actually support. I have already seen some technical information on the IKEA website, but some of it seems a bit vague or very general. Specifically, I am interested in how many kilograms a single shelf can safely hold without bending or damage occurring. This is especially important for heavy books or electronic devices.
I also want to know if the load capacity is always the same, or if it varies depending on the width or the materials used (for example, different panel thicknesses or types of fastenings). Are there any practical experiences or tips on how to increase the load capacity? For example, by adding extra supports or special reinforcements?
I know that IKEA generally provides maximum load specifications, but maybe someone here has practical advice or precise measurement results. Thanks in advance for your feedback!
jokau
12 Sep 2016 21:44
The official information from IKEA usually states about 15 kilograms (33 pounds) per shelf for PLATSA. This applies to the standard shelves with a thickness of 16 millimeters (0.63 inches). To carry more weight, additional supports or shorter shelves can help. At the same time, the load limits should not be exceeded, as this can cause the wood to bend.
Joshbe
13 Sep 2016 08:19
Regarding the load capacity of the IKEA PLATSA shelves: The typical panel thickness is 16 mm (0.63 inches) MDF with a melamine coating, which has limited load-bearing capacity. According to the manufacturer, the recommended maximum load per shelf is approximately 15 kilograms (33 pounds).
The load capacity varies depending on the shelf length, attachment method, and support points. Stability is best ensured with a length of up to 60 cm (24 inches). Longer shelves (> 80 cm / 31 inches) tend to sag more quickly due to the increased span.
The load capacity can be improved by the following measures:
- Installing additional center supports
- Using metal brackets or reinforcement strips on the underside of the shelf
- Using shorter shelves to reduce the span
For electronic devices or thick books, it is always advisable to check their individual weights beforehand and adhere to the specified limit to avoid overloading the material.
tuFernando
14 Sep 2016 12:02
Joshbe schrieb:
The typical panel thickness is 16 mm MDF with a melamine coating, which has limited load-bearing capacity.
That’s true, I’ve already noticed how quickly a shelf can visibly sag when you exceed the load limit. It’s especially frustrating when you rely on the shelf to remain stable.
I think it’s important to set your own priorities – small unevenness or slight sagging doesn’t necessarily have to be a problem, as long as there are no cracks or breaks. Still, of course, it’s better not to overload the shelf to avoid disappointment later.
Personally, I reinforced my shelves for books with additional metal brackets because I have many heavy technical books. This helped to adjust the effort to a certain level. I hope this little experience encourages others to adapt their solutions themselves rather than relying solely on the manufacturer’s specifications.
