I am planning to get an Ikea Pax sliding door wardrobe but have concerns about the stability of the sliding doors under heavy load. Specifically, I am interested in how much weight the sliding doors of the Pax system can withstand over an extended period—whether from leaning heavy objects against them, frequent opening and closing, or attaching additional elements to the doors.
Are the tracks and rollers sturdy enough to handle a high load without bending or losing functionality? Are there any user experiences regarding how the doors perform under heavy use after several months or years? I’m especially interested in feedback from users who have heavily used the Pax sliding doors or faced similar stress situations.
Thanks very much for your assessments and tips!
anrosa schrieb:
I am especially interested in user experiences from those who heavily use the Pax system with sliding doors or have similar high-stress situations.I can understand why you’re concerned. I’ve been using my Pax wardrobe with sliding doors for about 2 years now. In my case, the doors are subjected to moderate use—no extremely heavy items or additional mounted objects.
What I can say is that the sliding mechanism is sturdy and still closes well even after a long time. However, it’s important to ensure the doors are always properly adjusted—this also helps prevent damage caused by overloading.
To be honest, I sometimes worry that under heavy and continuous load, the tracks and rollers might reach their limits. Especially if there is deformation caused by pressure or by “hanging” on the doors. However, these kinds of experiences I’ve mostly heard about in other forums rather than from my own use.
Hello anrosa,
to address your question in a structured way, here are some important points regarding the stability of Ikea Pax sliding doors under heavy load:
- Tracks and rollers: These are made of metal and plastic, support the doors well, but are designed for a recommended maximum load specified by Ikea (around 10-15 kg (22-33 lbs) per door panel, depending on the model).
- Avoid load on doors: The doors are primarily meant for opening and closing, not for direct weight-bearing. Constant leaning or weight on the doors can lead to bent tracks or worn rollers.
- Installation and adjustment: Proper installation and regular adjustments are crucial for durability. Even slight misalignments increase the strain on moving parts.
- Practical experience: Many users report stable doors under normal use, but frequent pulling or pushing from the side can affect the mechanism.
In summary: Pax sliding doors are solid but not ideal for heavy weight on the door surfaces. If higher load capacity is needed, consider alternatives or reinforcements.
I hope this information helps you!
Hello anrosa,
I would like to share my experience as well, since I have been using an Ikea Pax sliding door wardrobe myself for almost 3 years and the doors are subjected to quite heavy use.
In my case, the doors are often opened and closed, and I once attached an additional magnetic strip for knives on the inner side of one door, which adds some weight and pressure on the door.
On the positive side, the tracks are very well made, which keeps the function stable over a long period of time. However, I had to readjust the doors after about 1.5 years because they had slightly warped. This was easy to do, but it shows that with heavy use and stress, a certain amount of maintenance is to be expected.
Regarding weight, I would recommend only moderate loads directly on the doors. Heavier items like shelves or similar should be placed inside the wardrobe to relieve the tracks.
If you plan to frequently put a lot of weight on the doors, you might consider installing additional guides or reinforcement elements. To my knowledge, the system is not designed for fully load-bearing sliding doors, but with some care and maintenance, this should not be a problem.
REPITAR schrieb:
Sliding tracks and rollers: These are made of metal and plastic, and support the doors wellThat's correct, the materials are sturdy, but don’t overload the doors. If they carry too much weight, the rollers will grind, or the track can get damaged.
GiRoyce schrieb:
I had to readjust the doors after about 1.5 yearsThis is important: regular adjustment extends their service life. Sliding doors are not a rigid structure; they always shift somewhat.
