ᐅ How long does a Pax wardrobe door last with daily use?
Created on: 16 Jul 2024 08:17
Z
Zoekau
I am currently looking into the durability of IKEA Pax wardrobe doors in everyday use and would like to learn how long such a door realistically lasts with daily opening and closing, without significant damage or loss of function.
Specifically, I am interested in:
- How long do the hinges and mechanical parts typically last?
- Are there common weak points in the doors that tend to cause problems after some time?
- How often is it usually necessary to readjust or replace parts with daily use?
- Does anyone have experience with particular stresses, such as high humidity or very frequent opening?
I would appreciate reliable user experiences or technical assessments to better estimate the lifespan of Pax wardrobe doors under real-life conditions.
Thank you in advance!
ju_ren
17 Jul 2024 07:44
Pax doors: with daily use, the hinges on mine have remained stable for 4 years, with only one adjustment needed. It is important not to leave the screws too loose.
gregto
17 Jul 2024 08:59
Hello Zoekau,
I would like to add that besides mechanical durability, the quality of the installation also plays a crucial role.
- If doors are installed crookedly, wear on the hinges and wooden components increases.
- Excessive load from heavy storage can overload the hinges.
I have seen with several users that with careful installation and regular checks of the screws, a service life of 7–10 years is quite realistic.
If you like, I can give you some tips on how to properly make adjustments.
Just get in touch.
Joshbe
17 Jul 2024 12:03
I completely agree.
In my experience, with correct installation and maintenance, replacing individual hinges is often necessary after 8 to 10 years, while the doors themselves usually remain intact.
The design is functional but tends to save on high-quality materials in the hinge area.
KAULIS
18 Jul 2024 09:21
Zoekau schrieb:
How long do the hinges and mechanical parts last?
To add: The hinges are often made of steel with a zinc coating to prevent corrosion. Plastic components are tested for durability according to IKEA quality standards and typically last several years under normal use.
Nabla64 schrieb:
Regularly tightening the screws.
This should be done every 12 to 24 months, especially for frequently used doors.
Conclusion: For an average household, a lifespan of 7 to 10 years is realistic, provided the doors are not overloaded and the installation is done correctly.
