ᐅ How long does it usually take to assemble a complete Ikea Pax wardrobe?
Created on: 17 May 2021 14:23
kopeo2Hello everyone,
I am currently planning to buy an IKEA Pax wardrobe and would like to know: How long does it typically take to assemble a wardrobe like this?
I am especially interested in the time required if you want to install all parts, such as the carcass, doors, drawers, and interior fittings—how many hours should you roughly expect if you assemble it yourself without professional help?
Perhaps you can also tell me if there are common pitfalls that significantly extend the assembly time. Are there differences for larger models or additional accessories?
Thanks in advance for your insights!
Hello kopeo2,
Regarding your question about how long it takes to assemble an IKEA Pax wardrobe, here is a structured overview based on my experience and that of many acquaintances:
- Preparation and sorting of parts: about 30 minutes
- Assembly of the carcass (frame, sides, back panel): 1.5 to 2 hours
- Installation of the interior fittings (rods, shelves, drawers, accessories): 1 to 1.5 hours
- Attaching the doors (sliding doors or hinged doors): 0.5 to 1 hour
This adds up to approximately 3.5 to 5 hours for an average wardrobe (about 100-150 cm (40-60 inches) wide, 2 m (6.5 feet) high) with typical experience.
Common pitfalls:
- Incorrectly connecting the fasteners (especially with drawers)
- Aligning and adjusting the doors can be time-consuming, especially sliding doors
- Incomplete or misunderstood instructions – be sure to follow the guide step by step
Tip: It’s best to work with two people, as this speeds up the assembly and makes handling large parts easier.
For larger models or additional elements like interior drawers, expect assembly time to increase by 1-2 hours.
I hope this helps!
Common pitfalls:
I hope this helps!
LOJOPAR schrieb:
Typical pitfalls:
- Incorrectly connecting the joining mechanisms (especially with drawers)
- Aligning and adjusting the doors can be time-consuming, particularly sliding doors
- Incomplete or misunderstood instructions – it’s essential to follow the manual step by stepThat sums it up very well. I would add that it’s particularly important to take your time during the planning phase. For example, deciding between sliding doors or traditional hinged doors greatly affects the assembly time. Sliding doors look great but require a lot of patience when hanging and adjusting them, especially at the beginning.
The tools you use also make a big difference. A good cordless drill will speed things up compared to a screwdriver. A tape measure and a spirit level are also recommended to ensure everything is perfectly aligned.
If you sort all the parts beforehand and assemble everything on a large, clean workspace, the process will go much smoother and with less stress.
Especially for first-time assemblies, it’s advisable to plan breaks in advance and proceed step by step to avoid frustration. Good luck with the build!
To add some details: The actual assembly time for an IKEA Pax wardrobe varies depending on experience, but also significantly on the model size and additional components.
Some straightforward facts:
- A single Pax carcass (typically about 50-100 cm (20-40 inches) wide) takes around 1.5 to 2 hours to assemble.
- Interior fittings such as shelves, drawers, and clothes rails require an additional 30 to 90 minutes depending on quantity and complexity.
- Installing doors depends on the type: hinged doors take about 30 to 45 minutes, sliding doors up to 60 minutes or more.
Furthermore, an experienced assembler working under optimal conditions (quiet workspace, good tools, working in pairs) can significantly reduce these times.
For more complex configurations with extras like lighting, internal drawers, or special interior elements, expect at least an additional 30 minutes.
Summary: Realistically, for a complex, well-equipped wardrobe, plan for 4 to 6 hours.
Anyone who only skim-reads the assembly instructions risks significant delays. Careful reading and working are therefore essential.
