ᐅ How can Ikea BRIMNES be used effectively in limited spaces?
Created on: 3 May 2024 08:13
muruna
I am currently considering how to make the best use of the Ikea Brimnes furniture range when space is very limited. Specifically, I am interested in how to arrange the modular elements, such as beds with built-in storage, wardrobes, or dressers, so they meet storage needs without making the room feel too cramped.
So my question is: What is the most effective way to use Ikea BRIMNES in small spaces? Which combinations or organizational options are recommended to use available space efficiently? Are there any tips for arranging or using the drawers and compartments that you could share?
Thank you in advance for your advice and experiences!
blapau
4 May 2024 14:54
benon schrieb:
Narrow two-door cabinets instead of large wardrobes.
This is very relevant.
Additionally, I recommend customizing the furniture to fit existing niches or corners. Brimnes allows flexible construction, combination, and partial adjustment.
If space is limited, also plan for the clearance needed to open drawers. Some under-bed drawers require a certain depth to be truly practical. Check whether there is enough room in the space to physically open the drawers.
From my personal experience, efficient use of space by stacking boxes inside the cabinet (instead of filling it completely) can save time when searching.
bauku
5 May 2024 09:31
What really convinced me about BRIMNES when dealing with limited space is the combination of a storage bed and a chest of drawers! 😃 Especially when living in small rooms, this makes the space feel much larger because you don’t have to put in countless pieces of furniture.
Tip: Try out different layouts on paper and play around with the dimensions—it’s worth it! You can also organize the drawers under the bed very well with compartments and boxes.
The flexibility of BRIMNES is brilliant if you truly consider the space. Good luck!
CHENFAR
5 May 2024 11:22
muruna schrieb:
How to best use the Ikea BRIMNES especially in limited space?
From a practical perspective, the following points can be noted:
- The modular design of BRIMNES allows adaptation to various room sizes.
- Combining a storage bed with matching dressers or cabinets optimizes space utilization.
- It is essential to consider clearance areas, especially for drawer openings; successful planning relies on accurate measurements and space assessment.
- Using organizing boxes inside the drawers increases usable capacity and improves orderliness.
Conclusion: The efficiency of the system largely depends on individual planning, taking into account all dimensions and accessibility.
