ᐅ How can Ikea BRIMNES be used effectively in limited spaces?
Created on: 3 May 2024 08:13
muruna
muruna
3 May 2024 08:13
I am currently considering how to make the best use of the Ikea Brimnes furniture range when space is very limited. Specifically, I am interested in how to arrange the modular elements, such as beds with built-in storage, wardrobes, or dressers, so they meet storage needs without making the room feel too cramped.
So my question is: What is the most effective way to use Ikea BRIMNES in small spaces? Which combinations or organizational options are recommended to use available space efficiently? Are there any tips for arranging or using the drawers and compartments that you could share?
Thank you in advance for your advice and experiences!
Jensson
3 May 2024 09:46
Hello muruna,
I’d be happy to provide a structured response on how to best use Ikea BRIMNES in limited spaces.
1. Beds with storage: The BRIMNES beds include drawers underneath the bed – this is invaluable for small rooms because it creates additional storage without needing extra furniture. Make sure the drawers are easily accessible, otherwise you might get frustrated with impractical drawers.
2. Combining wardrobes and dressers: BRIMNES wardrobes can be customized modularly, for example, combination wardrobes with multiple compartments for clothes and other items. If you have limited space, narrow versions are recommended.
3. Organization systems: Use boxes or dividers inside the BRIMNES dressers to make the most of the drawer space. This keeps everything organized.
4. Space planning: Measure the room carefully beforehand and plan the furniture so that walkways remain clear. Sometimes a slight angle or a tighter arrangement can be worthwhile.
I hope these tips help you! If you have a specific room situation, feel free to share the dimensions here, and I’d be happy to take a closer look.
Nabla64
3 May 2024 10:28
Jensson schrieb:
The BRIMNES beds have drawers underneath – this is invaluable for small rooms
I would like to add: Drawers under the bed are a key feature when space is limited. When using them, it is important to choose ones with smooth-running rails.
I also recommend:
- Consider which items you need frequently and store them in the easiest-to-reach drawers.
- Less frequently used items can be placed further back or in less accessible compartments.
Regarding wardrobes: BRIMNES models are usually available in several widths. In narrow rooms, the narrowest option (around 60cm (24 inches) wide) is worth considering. This allows more freedom of movement.
And finally, a tip: Sometimes it works well to use the wall space up to the ceiling by building furniture higher. Although BRIMNES is not very tall, there are extension units available or you can combine it with other storage systems.
U
uslis47
3 May 2024 12:05
Hello muruna,
I would like to share some of my experience as a user of BRIMNES in very small apartments.
What helped me:
- Use rolling containers or the existing drawers as efficiently as possible, meaning not just for clothing but also for paperwork, electronic accessories, and keep everything organized in separate boxes.
- If you have limited wall space for cabinets, consider placing additional shallow storage boxes under your BRIMNES bed that you can easily pull out.
- Sometimes it’s better to skip headboard shelves or choose ones with very little depth to avoid making the space feel cramped.
In any case, you should definitely work with a tape measure and sketches before purchasing so that nothing feels too tight later on. The width, depth, and height of the furniture have a significant impact.
benon
3 May 2024 14:17
Short and to the point:
Use the BRIMNES bed with drawers to save space for dressers.
Choose narrow 2-door wardrobes instead of large closets.
Boxes and organizers in the drawers are essential.
Check carefully where the access to the drawers is, otherwise it won’t fit.
That's all you need if you have limited space.
GALENKU
4 May 2024 07:42
I have used BRIMNES combinations in my small apartment like this: a bed with 2 large drawers, one for clothes, one for bedding.
Next to it, a narrow wardrobe with fixed shelves, which I fill with boxes.
Important: Don’t overstuff the dressers, or it becomes hard to keep things organized.
