ᐅ How durable are IKEA Brimnes furniture pieces for frequent moving?
Created on: 12 Apr 2021 09:04
Pin65
Hello everyone, I am planning to move several times in the near future and am wondering if the IKEA Brimnes furniture is sturdy enough for frequent moves. Since the furniture is often made from particleboard and relatively simple joints, I’m curious how well it holds up to repeated assembly and disassembly. Does anyone have experience with how durable Brimnes dressers or beds are when taken apart, transported, and rebuilt multiple times? I would appreciate if you could share your opinions or tips, especially if there are any weak points that tend to wear out quickly when the furniture is moved often.
Rensan3
13 Apr 2021 09:07
I had Brimnes dressers in a shared flat. After moving twice, some drawers became a bit stiff. For greater stability, it might be worth considering not fully disassembling the furniture but only partially.
Pin65
13 Apr 2021 10:15
Thank you very much for the detailed and helpful contributions!
To summarize once again: Brimnes furniture is generally sturdy enough for occasional moves, but frequent disassembly and reassembly mainly cause wear on the screw holes and joints, especially with drawers and corner connections.
Handling with care during assembly and disassembly, avoiding overtightening, using wood glue or repair kits, and careful transport focusing on corners and edges can help extend its lifespan.
If I may ask specifically: Would you recommend buying Brimnes furniture for someone who moves 3-4 times a year, or would it be better to consider a different, more durable series?
KUDAISY
13 Apr 2021 10:48
Pin65 schrieb:
Would you recommend buying Brimnes furniture for someone who moves 3-4 times a year?
For such a high moving frequency, Brimnes furniture is not ideal. I would rather choose higher-quality furniture made of solid wood or with better joinery techniques.
Alternatively, you can use Brimnes if you are willing to carry out regular repairs and obtain replacement parts. This requires time and can sometimes be frustrating.
So: yes for occasional moves, no if you move more often and frequently.
