ᐅ How can tall Pax wardrobes be stabilized without attaching them to the wall?
Created on: 13 Feb 2020 08:37
lujemiHello everyone,
I am planning to get a tall Pax wardrobe from IKEA, but I face the issue that, due to building regulations or rental agreements, I am not allowed or do not want to fix the wardrobe to the wall. My question is therefore: How can a large, somewhat unstable-looking Pax wardrobe be reliably stabilized without anchoring it to the wall?
I am particularly interested in methods that have proven effective in preventing tipping or wobbling when heavily loaded. Are there specific technical solutions I can use besides wall mounting? Any advice on suitable accessories, support feet, or alternative fixing options would also be helpful.
I want to set up the wardrobe as safely and securely as possible without having to drill into the wall. Thank you very much for your experience and recommendations!
Hello lujemi,
Your question is very practical and addresses a common issue, as not every cabinet can or should be fixed to the wall. Basically, with tall Pax wardrobes, the goal is to keep the center of gravity as low as possible and mechanically reduce the risk of tipping over.
First, you should check if the cabinet’s base is completely level. Unevenness increases instability. If necessary, the adjustable feet on Pax wardrobe models can be set differently to compensate for uneven floors.
A proven step is to add weight to the lower section—such as sandbags or heavy items in the bottom compartment, if visible. This lowers the center of gravity.
In addition, there are the following alternatives to wall fixing:
- Using so-called corner brackets to connect multiple Pax wardrobes together. This provides lateral reinforcement.
- Installing special anti-tip plates under the cabinet, which create stability through their own weight and adhesion to the floor surface.
- Using feet with a larger contact area or rubber pads that prevent slipping.
Don’t underestimate the importance of load distribution inside: always place heavy items at the bottom and lighter ones at the top. This significantly reduces the tipping moment.
Finally, if your flooring is hard (tiles, parquet), sometimes using non-slip mats (e.g., rubber mats) can help improve stability.
Are there any specific conditions with your floor covering or cabinet size? That could allow for more tailored advice.
Quote from danial60, post: i4d0j9, member: XXX
"That lowers the center of gravity."
A consistent lowering of the center of gravity is essential.
Additionally, I recommend the following two points:
- Directly connecting multiple cabinets or modules increases overall rigidity. The individual elements stabilize each other.
- A wider base or platform feet can be installed to increase the contact area. Custom-built wooden frames underneath that effectively embed the cabinet are also effective.
As another option, there are often systems with additional floor anchors or retrofit base plates that improve stability without affecting the wall.
Preventing slipping on smooth floors is another important factor. Here, the combination of non-slip mats with wider feet is advisable.
Please also check whether your rental agreement has any restrictions on drilling, as some stabilization methods require a small hole in the floor surface, which may be allowed by the landlord.
Overall conclusion: A combination of lowering the center of gravity, increasing the contact area, and connecting modules is the most effective approach.
