ᐅ How can Ikea Pax wardrobes be safely mounted to the wall?
Created on: 4 Jun 2020 08:24
Runekla
Hello everyone, I am planning to secure my new Ikea Pax wardrobe to the wall to ensure maximum stability and safety, especially since I have children at home. My specific question is: How can Ikea Pax wardrobes be mounted securely and professionally to the wall to prevent tipping?
I understand that Ikea requires wall fixing, but is the supplied bracket sufficient? Which plugs and screws are best suited for different wall types (concrete, drywall, brick)? What important precautions should be taken to avoid accidents?
Additionally, I am curious if there are differences when mounting individual units versus assembled wardrobe sections. I have already done some research but would greatly appreciate tips from experienced users here. Thanks in advance!
Runekla
4 Jun 2020 11:28
KIN42 schrieb:
I therefore always recommend knowing the exact weight of the wardrobe and sizing the screws accordingly.
Thanks for the tip! I just checked on the Ikea website—the Pax wardrobe measuring 100x60x201cm (39x24x79 inches) weighs nearly 60 kg (132 lbs) empty, according to the manufacturer. With hangers and other items, it will be significantly heavier—so I think the wall plugs should be rated for at least 50 kg (110 lbs) each?
Are there any recommendations for specific brands or preferred screw diameters based on your experience? What can be used on brick walls if heavy-duty anchors are harder to find?
And one more thing on the topic: Is it better to screw the wardrobe to the wall first and then install the hanging rods and shelves, or vice versa?
praWarre69
4 Jun 2020 11:59
Runekla schrieb:
Are there any recommendations for specific brands or screw diameters that you have preferred based on experience?
When it comes to brands, well-known names like Fischer or TOX are top quality 👌 – they are durable and also easy to handle for DIY enthusiasts. For this type of cabinet, anchors with a diameter of at least 8 mm (0.3 inches) should be used, along with screws that are at least 6 mm (0.24 inches) in diameter to ensure a secure hold.
Runekla schrieb:
Is it better to screw the cabinet together first and then install the clothes rails and shelves, or the other way around?
I recommend fully assembling and mounting the cabinet frame to the wall first. After that, you can freely experiment with the shelves and rails – this way, you avoid having to detach everything later. 👍
RABLA
4 Jun 2020 12:14
Brand is not that important, the main thing is to have minimal play in the drilled hole.
For bricks, these work well:
- Wall plugs with nails
- Chemical anchors
And yes, install first, then fill.
Katan
4 Jun 2020 13:47
A small additional tip: I attached my Pax to an older stone wall using heavy-duty bonded anchors with threaded rods, which worked best for me. For the final phase, it’s very helpful to use a spirit level – I’ve installed cabinets crookedly before and had to adjust them annoyingly afterward.
And Runekla, don’t worry, they don’t cause any instability; once installed, they are completely secure. Just take it step by step, and if needed, get two people to help – then everything goes smoothly.
Also, don’t forget to use more screws than just the two brackets, especially for wider cabinets.
FLONE41
5 Jun 2020 07:22
Katan schrieb:
Attach a few more screws than just the two brackets, especially for wide cabinets.
Absolutely! With my Pax, I even used three or four brackets spaced out. It just feels more secure and distributes the load better.
Briefly returning to the topic of wall type: what I did was a small drill test in an inconspicuous spot to see how the material reacted (whether it crumbled or was stable). This gave me planning certainty and increased confidence when fastening.
Demetrius
5 Jun 2020 08:13
I completely understand the desire for safety, especially from a family perspective. Here’s a quick tip from me:
If you connect the cabinets using so-called expansion hinges or connecting screws between the individual Pax units, it significantly increases stability and further reduces the risk of tipping.
For me, these additional connections made all the difference, especially with larger combinations. It does add a bit more effort during assembly but is definitely worthwhile in the long run.
