ᐅ How can the Ikea PLATSA system be securely mounted to different types of walls?
Created on: 1 Oct 2021 09:17
FARID56
FARID56
1 Oct 2021 09:17
I am planning to attach an Ikea Platsa cabinet unit to a wall in my home and am looking for reliable methods to securely mount the structure depending on the wall type. Specifically, I am interested in how to ensure a secure attachment for:
- Solid walls made of concrete or brick
- Drywall with gypsum board
- Possibly also older, crumbly clay or timber-framed walls
My main concern is choosing the appropriate anchors and screws, as well as the recommended procedure for drilling and installing the fasteners. Are there proven techniques or specific products that work particularly well? I want to avoid the cabinet wobbling later or even dangerously falling off the wall.
Thank you in advance for your expertise!
glamo
1 Oct 2021 11:43
Hello Farid,
to thoroughly answer your question about securely fixing Ikea PLATSA furniture to different wall types, here is a detailed approach:
First, it is crucial to identify the exact wall type, as the fastening methods depend heavily on this:
- Solid walls (concrete, brick): Here, the use of hammer drills and chemical or metal anchors such as heavy-duty anchors (e.g., metal expansion anchors or bolt anchors) is recommended. Pre-drill with a masonry bit, then insert the appropriate anchor – this ensures high load-bearing capacity.
- Drywall (gypsum board/plasterboard): Classic expansion anchors are not sufficient here. Better options are special cavity anchors or metal toggle bolts that spread behind the board. Alternatively, you can install a backing rail (e.g., a wooden batten) behind the wall to better distribute the load. It is important that the size of the anchors and the length of the screws match the weight of the fully loaded PLATSA.
- Clay or timber-framed walls (wattle and daub, half-timbered): Caution is advised as the material is often porous or brittle. If possible, loads should be distributed onto load-bearing beams or joists, possibly using additional substructures. Chemical anchors or injection mortar can increase holding strength but require experience during application.
Recommended procedure:
1. Check the wall: Use a magnet, hammer, or a light test to locate stable points.
2. Mark drilling holes and pre-drill with the appropriate drill bit.
3. Insert anchors suitable for the wall type.
4. Screw into the anchors and attach the PLATSA mounting bracket.
Tip: Ikea provides brackets intended for solid walls but not explicitly for drywall/plasterboard. For light walls, always use additional measures (reinforcement or cavity anchors).
If you can specify your exact wall type, I can provide more targeted advice, since the safety of the mounting depends greatly on the details.
O
onMarcos
2 Oct 2021 14:05
Hello Farid,
I will address the topic in a structured way and summarize how to securely attach the Ikea PLATSA to different wall types, including important notes on common mistakes.
1. Solid walls (concrete / brick):
- Drill bit: masonry drill bit, diameter matching the anchor.
- Anchors: use heavy-duty anchors (metal or nylon expansion anchors) that engage deeply.
- Screws: at least 6 mm diameter, length depending on anchor size.
- Important: clean out the drill hole thoroughly, insert the anchor fully.
Common mistake: anchors not seated properly or drill hole not deep enough.
2. Drywall (gypsum board):
- Load capacity is limited because only the gypsum board itself is directly bearing the load.
- Best option: metal toggle anchors that expand behind the board.
- Ideal: if there is a stud (wood or metal framing) behind the drywall, attach long screws directly into the stud.
2a. If no studs are present, reduce the weight significantly:
- Use furniture feet or keep the unit freestanding.
3. Clay or timber frame walls:
- It is recommended to screw the furniture frame directly into the load-bearing beams.
- Alternatively, use injection mortar, but this requires experience and special tools.
I always recommend thoroughly studying Ikea’s assembly instructions before mounting and matching the included fixing materials to your wall type.
glamo schrieb:
If you can specify which wall type you have, I can provide more targeted help. The safety of the mounting depends greatly on the details.
That is an important point. Could you provide more information about the wall structure? Then I can recommend specific drill bit and anchor sizes.
Summary:
- Solid wall = heavy-duty anchors + masonry drill bit
- Drywall = toggle anchors + ideally studs
- Older walls = distribute load on beams or use specialized solutions
This way you won’t take any unnecessary risks.
jaanda
4 Oct 2021 08:52
To complement the previous information, I would like to provide some specific advice regarding the secure installation of the Ikea PLATSA, which is particularly important from a work safety and load-optimized construction perspective:
- The maximum allowable load per fastening point should not be exceeded. Ikea usually specifies this in the manual; generally, around 15–20 kg (33–44 lbs) per screw is realistic.
- For concrete block walls, chemical anchors combined with bolt anchors are especially suitable when maximum safety is required.
- For drywall installations, especially with heavier cabinets, it is advisable to install additional floor-level supports in addition to wall fastenings to counteract tipping forces.
- For older or damaged walls, I strongly recommend consulting a professional before installation to assess the load-bearing capacity. Relying solely on wall plugs is not advisable if the masonry is crumbly.
- In general: work carefully when drilling, remove dust (e.g., using compressed air), and use appropriate wall plugs exactly according to the manufacturer’s instructions.
The combination of proper fastening techniques and consideration of wall type makes all the difference. Cutting corners or experimenting here risks instability of the furniture and potential accidents.
Finally, one more thought: always consider the intended use during assembly, for example, whether the cabinet will be frequently moved or constantly loaded. In such cases, it is better to install one or two additional fastening points.
