ᐅ How do you repair surface damage on IKEA HEMNES furniture?
Created on: 7 Aug 2024 08:17
Solafe
Solafe
7 Aug 2024 08:17
I have several Ikea Hemnes furniture pieces in my apartment that I really like, but unfortunately, some unsightly scratches and small dents have appeared on the surfaces over time. These surface damages are especially noticeable on the white or natural-colored Hemnes items.
My question: What is the best way to repair these damages myself without making it obvious? Which tools, materials, and methods work particularly well for this type of wood finish?
I want to do this as sustainably as possible without completely replacing the surface. Maybe there are special repair kits or techniques that work well?
I appreciate any tips, experiences, or warnings to avoid making mistakes.
Thank you in advance!
Nathanaelk
7 Aug 2024 08:52
Hello Solafe,
to professionally repair surface damage on Ikea HEMNES furniture, it is important to know that these pieces are usually made from solid pine wood and are either painted white or treated with oil. The repair method varies depending on whether you are dealing with scratches, dents, or deeper abrasions.
A step-by-step approach to follow:
- First, clean the damaged area to remove dust and grease.
- For small scratches, a wax stick or touch-up paint pen that matches the furniture color is often sufficient. Important: Test the color match beforehand.
- For dents where the wood is compressed, you can try raising them with steam. Place a damp cloth over the dent and briefly press a hot iron on top. This allows the wood fibers to expand again.
- Afterwards, gently sand the surface—preferably using very fine sandpaper (grit 320–400), only on the affected spot.
- If the surface is painted, it is recommended to apply a suitable acrylic or wood lacquer. Ideally, apply several thin layers and let each dry thoroughly.
- Finally, you can polish the area to blend the repair with the surrounding surface.
One important note: HEMNES uses different surface finishes (painted, oiled, waxed), so it’s important to know which version your furniture has. Can you tell me which finish your pieces have? That way I can tailor the advice more specifically.
Best regards!
te-min
7 Aug 2024 09:15
Simply use fine sandpaper, then treat with a wax stick matching the color, and finally finish with furniture polish.
klo61
7 Aug 2024 11:03
Hello Solafe,
I am familiar with your situation, as I used to have many HEMNES pieces at home. It is always important to properly assess the damage first. For superficial scratches, a special repair felt pen has proven very practical to smooth out and discreetly fix small spots.
If the scratch is deeper, I like to use a wood filler repair kit that you apply with a spatula. After that, I lightly sand the area if needed, then apply a suitable varnish or sealant on top.
Don’t forget: wood reacts to moisture and temperature. After repairs, it’s best to let the furniture acclimate slowly. This helps prevent unwanted expansion or cracks.
If the piece is waxed: wax enhances protection and appearance, so it’s better to apply several thin layers, sanding between coats.
I personally always use a repair kit specifically suited for Ikea furniture – these kits usually include touch-up paints, waxes, and care products and are well matched to the surfaces.
I’m happy to answer further questions if you have more details.
blapau
7 Aug 2024 14:22
Nathanaelk schrieb:
An important note: HEMNES uses different surface treatments (painted, oiled, waxed), so you should be aware of this.
This is a key point. For oiled HEMNES furniture, you should definitely avoid using paint, as it seals the surface and destroys the characteristic oil finish. Instead, re-oiling with the original oil or a suitable maintenance oil often helps.
When it comes to painted furniture, it can be lightly sanded with fine sandpaper and repainted, but it is important to use paint that exactly matches the color. Manufacturer’s colors or special wood repair kits can be helpful here.
Another tip: small tubes of touch-up paint for furniture are available at specialized retailers. These can be easily applied and, once dry, sanded or polished to make repairs nearly invisible.
If you do not want to change the surface, wax sticks to minimize scratches are a simple alternative.
Dilen
8 Aug 2024 07:47
Hello Solafe,
I’d like to add a few more details to the previous tips because preparation and choice of materials are especially important for furniture like HEMNES.
- First, clean the piece thoroughly to remove all dirt particles; microfiber cloths with a little mild dish soap work best.
- For minor scratches, I recommend using wax sticks, as mentioned before, but pay attention to the wax composition: it should be solvent-free to avoid damaging the finish.
- For deeper damage, I would mix wood filler made from pine wood powder with wood glue. This matches the color tone of HEMNES solid wood best. After drying, gently sand the area (grit 320) and then apply a fine coat of paint.
- When applying paint, always use several thin layers instead of one thick layer. Don’t forget to sand lightly between coats! This way, you achieve a smooth and even surface.
- For oiled surfaces: re-oil with care oil designed for pine. It’s also important to buff afterwards so the wood absorbs the moisture well.
If you want, I can prepare a detailed materials list for you.
How large are the scratches and how severe is the damage? That would help to determine the appropriate next steps.
