I have several Ikea Hemnes furniture pieces in my apartment that I really like, but unfortunately, some unsightly scratches and small dents have appeared on the surfaces over time. These surface damages are especially noticeable on the white or natural-colored Hemnes items.
My question: What is the best way to repair these damages myself without making it obvious? Which tools, materials, and methods work particularly well for this type of wood finish?
I want to do this as sustainably as possible without completely replacing the surface. Maybe there are special repair kits or techniques that work well?
I appreciate any tips, experiences, or warnings to avoid making mistakes.
Thank you in advance!
blapau schrieb:
HEMNES uses different surface treatments (painted, oiled, waxed), so you should be aware of that.Thanks for the tip, I had already suspected that. I mainly own white painted Hemnes furniture – so not oiled or waxed. The scratches are mostly superficial, but in some areas a bit deeper, especially around the edges.
Dilen schrieb:
How large are the scratches and how severe is the damage?They are usually 1-3 cm (0.4-1.2 inches) long, not very deep – more like scuffs rather than going into the wood. I would therefore like to try to remove as little material as possible and restore a smooth surface.
One more question: Is it advisable to treat the entire furniture surface again after the repair, for example with a clear varnish or polish, to protect the result and even out the color? Or could that quickly become noticeable and perhaps counterproductive?
Nathanaelk8 Aug 2024 14:02Solafe schrieb:
Is it advisable to treat the entire furniture surface again after a repair, for example with a clear varnish or polish, to protect the result and even out the color? Or can this quickly become noticeable and rather counterproductive?That’s a very good question, Solafe.
In general: If you re-treat the whole surface after a localized repair, it can indeed cause differences in color and gloss, especially if the furniture is older and has already developed a patina.
So if you completely renew the varnish, make sure to use exactly the same color tone and finish. Ideally, use the original IKEA varnish or a comparable product with the matching finish (matte, satin, etc.).
An alternative is to carefully seal only the repaired area with a matte polish, which is easier to blend in and less noticeable.
The most important goal for repaired spots is to interfere as little as possible with the undamaged surfaces — a uniform gloss all over is better than patchy varnish that stands out.
For protection, a gentle furniture polish or wax treatment is also recommended, as it maintains the gloss and provides additional protection.
How closely you stick to the original materials will determine the result. If you like, I can also share product recommendations and sources.
May I ask how you proceed step by step with the repair?
Solafe schrieb:
I want to try to remove as little material as possible and restore the surface to smoothness.That is a good approach. For white, painted surfaces like those on HEMNES furniture, I recommend carefully sanding the scratches and then applying a very thin layer of white touch-up paint.
It is important to allow sufficient drying time between multiple thin coats to prevent uneven buildup or visible transitions.
Finally, you can gently polish the area with a soft cloth and possibly finish with a mild furniture polish.
This method results in a discreet repair that provides lasting protection and closely matches the original appearance.
If you are unsure, start on a less visible area to test the color match.
