ᐅ How do you fix Ikea Brimnes cabinets with loose screws?
Created on: 28 Jun 2020 08:47
Sujaben
Sujaben
28 Jun 2020 08:47
some time ago I assembled an Ikea Brimnes wardrobe, but I’ve noticed that the screws, especially on the wardrobe doors, keep loosening over time. This causes the doors to no longer fit properly and to feel a bit wobbly. I suspect the material weakens over time due to the frequent opening and closing, which makes the joints less secure.
Has anyone had experience with how to best fix these loose screws without having to completely disassemble the wardrobe? Are there proven methods to secure the screws permanently or to reinforce the material? I would appreciate any specific instructions or tips, including recommendations for suitable tools or replacement parts.
Timofa
28 Jun 2020 09:16
Sujaben schrieb:
Does anyone have experience with the best way to fix loose screws without having to completely disassemble the cabinet?
Hi Sujaben, that sounds like a classic case of wood and screws not quite holding together anymore. A little trick: if the screws are just starting to wobble in the particleboard, you can try inserting a toothpick or small wooden strips coated with wood glue into the hole, let it dry briefly, and then screw the screw back in. This reinforces the material and tightens the connection again.
If the material is already significantly damaged, special repair inserts from a hardware store can sometimes help. Not perfect, but definitely better than rebuilding the entire cabinet! 😉
Germanro
28 Jun 2020 09:39
Insert wood glue and toothpicks into the loose screw hole, let it dry, then tighten the screw. Alternatively, choose a slightly larger screw.
BLAKEO
28 Jun 2020 10:05
Timofa schrieb:
If the screws start to loosen only in the particleboard, you can try inserting a toothpick or small wooden strips with wood glue into the hole
That is certainly a practical solution, but it does not address the root cause. Brimnes cabinets are often made from thin particleboard that can give way under load. Anyone looking for a more durable fix might consider using solid dowels or screws with longer threads.
It also remains questionable whether this repair will be mechanically stable in the long term, especially for frequently used doors.
Elias
28 Jun 2020 10:28
I completely understand the frustration with screws coming loose – I experienced the same with my Brimnes. What helped me was filling the screw holes with wood filler and lightly sanding them after drying. After that, I was able to tighten the screws firmly again without worrying about them loosening. It does take some patience, but it holds much better.
If you decide to try this, make sure to allow enough time for the filler to cure and be gentle with the pressure; then it should work well.
BELLA34
28 Jun 2020 12:02
Wood glue plus toothpicks usually works well. For heavily damaged holes, fill the screw hole with a wooden splint; otherwise, use longer screws. Otherwise, check the entire frame to ensure it is still stable.
