I have unfortunately discovered some broken parts on my Malm dresser, especially around the joints of the side panels and the drawer fronts. My question is quite specific: What is the best way to repair these broken parts without compromising the stability or appearance of the dresser?
I already have some experience with basic wood repairs but am unsure which adhesives or techniques are most suitable for the often veneer-covered panels of the Malm. Is there an optimal repair process, specific materials that work particularly well, or maybe tips for concealing visible damage?
I would really appreciate any practical experience, detailed step-by-step instructions, or tool recommendations, as I would like to preserve the dresser rather than simply buying replacement parts. Thank you in advance!
Hello MICAHSU,
I want to address the materials once again from the basics, as this is often overlooked: Malm dressers are made from particleboard with veneer, not solid wood. This means that breakage points are actually damage to a relatively thin layer applied over a less sturdy core.
Therefore, my advice:
- Do not apply too much pressure when screwing or gluing, as this can cause further damage to the material.
- Always use appropriate types of glue; PVAC works well.
- Test on scrap pieces in advance to see how the veneer reacts to moisture and pressure.
To hide visible damage, a wood repair kit designed specifically for IKEA veneers is recommended.
And very important: if the breaks are on load-bearing parts, it can help to glue in small wooden reinforcements on the inside.
You will surely do a good job if you proceed carefully. If you like, I can send you a detailed list of the recommended tools and materials.
