I have unfortunately discovered some broken parts on my Malm dresser, especially around the joints of the side panels and the drawer fronts. My question is quite specific: What is the best way to repair these broken parts without compromising the stability or appearance of the dresser?
I already have some experience with basic wood repairs but am unsure which adhesives or techniques are most suitable for the often veneer-covered panels of the Malm. Is there an optimal repair process, specific materials that work particularly well, or maybe tips for concealing visible damage?
I would really appreciate any practical experience, detailed step-by-step instructions, or tool recommendations, as I would like to preserve the dresser rather than simply buying replacement parts. Thank you in advance!
Hello MICAHSU,
First of all: Your question is very well formulated and shows that you have a good understanding of the topic. Repairs on MALM dressers made from particleboard with veneer can indeed be tricky, especially if you want to preserve the appearance.
Here is my detailed suggestion:
1. Preparation: All affected parts should be clean and dry. Carefully remove any loose veneer pieces without causing further damage.
2. Adhesive selection: For wood and particleboard, I recommend using high-quality wood glue (PVAC glue), as it dries clear and provides sufficient strength. For small cracks in the veneer, white glue also works well, but it should be applied thinly to avoid warping.
3. Reinforcing the broken areas: If it concerns load-bearing sections, I advise using small wooden dowels or glued-in blocks to stabilize the repair. This significantly increases strength. Pilot holes should be drilled very precisely, as particleboard can easily chip out.
4. Gluing technique: Apply the glue thinly and evenly. The parts must be clamped firmly together, ideally with screw clamps. A tip: Wipe off any excess glue immediately, as it can sometimes darken the veneer.
5. Surface touch-up: Small spots can be concealed with color-matched wax or marker pens. IKEA usually uses fairly light birch veneer, so wood repair kits for birch work well.
6. Drying time: At least 12 hours, preferably 24, before the dresser is loaded again.
I have the following question: Are the breaks mainly on visible surfaces, or are they more internal joints? Are drawers affected, and if so, do they still slide smoothly or are they difficult to close? That would help me give you more precise advice.
I hope this helps you already.
Hi MICAHSU,
That sounds really frustrating with the broken parts. I’ve experienced something similar with my MALM chest of drawers—especially when you store a lot inside or pull the drawers too hard, these issues can happen.
I just wanted to encourage you: with some patience and care, you can usually fix it. What I did myself was, after gluing, loosen all the screws again and apply some wood glue in targeted spots as an extra reinforcement.
Regarding the glue: I experimented and found that sometimes polyurethane (PU) glue works well and is a bit more flexible, especially if the joints are subject to slight stress. But it expands and needs to be used carefully.
Another thing I noticed—would you be willing to do some touch-up painting? Because in some places, color differences will be visible afterward. Not ideal, but better than having a lot damaged.
I’m curious how it will go for you. Don’t get discouraged—these things are just part of furniture ownership 🙂
Additional information:
The MALM is mainly made of particleboard with a thin veneer layer. This construction method has weaknesses when subjected to point pressure or stresses at connection points.
For repairing broken side or front parts, wood glue (PVAC) is the first choice. Alternatively, epoxy resin can be used, especially if higher strength is required.
Using wooden dowels or metal brackets can increase stability, but these are not ideal visually when used on visible parts.
For cosmetic repairs, repair wax or appropriately sized wooden plugs are suitable. Important: paint or pore fillers should be matched to products designed for light veneers.
The procedure:
1. Clean the broken surfaces
2. Apply the glue
3. Clamp with screw clamps
4. Allow to dry (at least 12 hours)
5. Surface touch-up
For drawers, it is advisable to regularly check whether the runners are still properly seated, as broken parts can affect functionality.
Careful documentation of which parts are broken helps for targeted replacement or reconstruction.
I recommend avoiding placing excessive weight on the furniture during repairs until everything is firmly set.
The procedure:
2. Apply the glue
5. Surface touch-up
Palenar schrieb:
If it concerns load-bearing areas, I recommend using small wooden dowels or glued-in blocks for reinforcement.I can only confirm that. For me, this is the most important step to really make the joints stable.
Also: Always apply firm pressure; otherwise, even the best glue won't hold.
Hey MICAHSU and all other repair heroes here! 🙂
First of all, respect for not just throwing away the MALM – these dressers somehow always have a place in our homes, don’t they? 😄
I tried a little trick that really helped me with broken drawer fronts: after gluing, I treated the surface area with a matching wood repair marker and then gently sanded it with fine-grit sandpaper. The result was surprisingly good – the damage is only noticeable if you look really closely.
One more tip: patience is key while the glue dries – don’t move it too early, or you’ll end up with more frustration than satisfaction.
Good luck, and if you want, feel free to share how it went! 😉
