ᐅ How can the load-bearing capacity of Billy bookshelf shelves be increased?
Created on: 1 Oct 2019 19:37
joey47Hello everyone,
I recently realized that the load capacity of my Billy shelves is simply not enough for what I want to store. Especially with the wider shelves, the wood bends noticeably in the middle under heavy weight, which doesn’t look good and isn’t really safe either. My question is: What is the best way to increase the load capacity of Billy shelves without significantly changing the visual design of the unit?
I am looking for simple, practical solutions as well as materials or reinforcements that can be installed to significantly improve stability. Does anyone have experience or tips on this topic, ideally with advice on possible costs or effort? Thanks in advance for your help!
The most effective way to reduce load on a shelf is to support it in the middle with an additional brace. For example, you can attach a narrow strip of wood or metal underneath the shelf by gluing or screwing it in place. Installing metal brackets on the sides can also improve stability. Simple, quick, and effective.
Hello joey47,
I think your question is very well formulated, as the physical limits of Billy shelves are often underestimated. Here is a short guide on how to significantly improve their load-bearing capacity:
1. Attach stiffening strips underneath: Use wooden strips (about 2x2 cm (1x1 inch), grain running lengthwise) and fix them to the underside of the shelf with wood glue and small screws or nails. This greatly increases bending strength.
2. Add a central support: Especially for wide shelves, a vertical support (e.g., a thin wooden beam or a metal pipe) that props up the shelf from underneath helps a lot.
3. Check shelf thickness: Sometimes, you can buy thicker or stronger shelves or replace the existing ones with plywood panels, which are more stable.
4. Metal brackets on the edges: Attaching stainless steel or aluminum brackets to the front and back edges of the shelf increases stiffness.
Common mistakes include incorrectly positioning the strips or only gluing them without screwing. Also, be careful not to overload the material. In summary, combining additional support and stiffening is usually the best solution. Good luck!
pinDavid schrieb:
The most effective way is to relieve the shelf in the middle with an additional support.I completely agree! Sometimes it’s the small tricks that turn a simple bookshelf into the true hero of the living room. 🙂
Personally, I would also recommend not only thinking about the central support but also about the choice of materials. Especially if you like to store heavy books or equipment, switching to stronger shelves can be worth it, as tolokau already mentioned.
In addition, metal brackets or a cross brace on the left and right provide the necessary stability—they are usually inexpensive and easy to install. And the best part: you can keep the design intact because these reinforcements often remain barely visible! 😉
My tip: make a bit of space while assembling and treat it as a small DIY project. It’s actually fun once you get started!
