ᐅ What is the best way to install lighting inside an Ikea Pax wardrobe?
Created on: 2 Dec 2017 19:23
aloispeo
I am currently planning to upgrade my Ikea Pax wardrobe system and would like to install suitable lighting inside. Since the wardrobe panels and shelves are relatively thin and I prefer to avoid visible cables or unsightly mounts, my question is: What is the best way to attach lighting inside the Ikea Pax?
Specifically, I am interested in:
- Which mounting methods (adhesive, screws, magnets, etc.) work reliably and cause minimal damage to the furniture?
- Are there any recommended built-in lights that are easy to integrate and provide good illumination?
- What is the best way to organize power supply without complicated cable routing?
I would appreciate it if you could share your experiences or tips on this topic. Thanks in advance!
aloispeo schrieb:
I’m just wondering if the adhesive tape will hold permanently if the inside of the cabinet occasionally gets a bit damp (for example, from slightly damp clothing or vapors)Moisture inside a Pax unit? A few drops of water are generally not the main issue, rather the air being too dry. But honestly: For people who want to stick and seal things “dry” permanently, LED lights without any mechanical fasteners are an illusion.
SUBEN60 schrieb:
Residue when removing is possibleExactly. I’m not a fan of adhesive solutions that leave your furniture “smeared” and are difficult to remove. It’s better to drill holes directly and use proper screws. After years, it won’t look like a glued-together accident.
My advice: If you want true durability, you should accept small drill holes. Everything else is just a temporary fix. But of course – it depends on how often you rearrange or redesign.
Wow, I really like this discussion! I personally installed LEDs on my Pax closet using 3M adhesive tape and I’m very happy with the results! It has held firmly for over a year, partly because I cleaned the surface with alcohol before applying the tape.
Another recommendation: use battery-powered LED modules with motion sensors! This saves wiring and eliminates the need for drilling. Especially in the bedroom, these gentle light sources are perfect when you need to get up at night.
So: go for it! It’s easy to do and provides great lighting. And if something goes wrong, the adhesive usually comes off without any problems 😉
