ᐅ How do you install Ikea PLATSA units together with other furniture?
Created on: 2 Jul 2022 08:43
Gugrahame
Gugrahame
2 Jul 2022 08:43
I am currently facing the task of not only assembling an Ikea PLATSA system at home by myself but also integrating it with existing furniture from another manufacturer. My main question is: How can Ikea PLATSA be installed so that it visually harmonizes well with other furniture while also being securely connected functionally?
Specifically, I am interested in which assembly methods you would recommend when, for example, cabinets need to be fixed together despite having very different constructions. Are there special connectors or installation aids available from Ikea or third-party suppliers? How do you handle potentially different materials and wall fixings? I want to avoid any unstable constructions and am aware of the “self-supporting” principle of PLATSA, but is that alone sufficient when additional furniture is integrated?
Also, it would be great to get tips on visual integration—how to best combine furniture of different colors or styles so that they work well together.
Thanks in advance for your experiences and feedback!
koduga
2 Jul 2022 09:37
Hello Gugrahame,
I completely understand how tricky such a combination can be – I recently faced almost the same challenge. It’s really important to first check how stable the individual modules of the PLATSA system are, as Ikea does emphasize a solid basic assembly.
Regarding your question about connectors: Ikea usually supplies special fittings for the PLATSA modules, but it gets more complicated if you add other furniture pieces. Back then, I used metal brackets or plates from the hardware store to strengthen the connections. The key is to avoid creating excessive stress, especially if the other furniture has a different construction.
About wall mounting: definitely use the supplied wall anchors – especially when you have several cabinets placed side by side. This greatly improves stability and prevents tipping.
Visually, minor adjustments like paint or special wooden trims can help soften the transitions. I had good results with colored films or wooden strips.
I hope this helps you for now! I’m curious to see if more tips will follow.
draleo
2 Jul 2022 11:04
Hello Gugrahame,
to answer your question about installing Ikea PLATSA together with other furniture in a structured way, I will summarize the key points:
- Connecting elements: Ikea PLATSA is modular and designed for standalone assembly by default. There are no official Ikea components for connecting it with other furniture. However, you can use angle brackets or screw plates from a hardware store to securely join the modules.
- Materials: Since different furniture often uses various materials (chipboard, MDF, solid wood), it is important to use the appropriate fasteners. For heavier constructions, you may need dowels and screws with high load capacity.
- Wall mounting: This is essential for larger combined furniture units. Make sure all parts are securely anchored to the wall—this increases stability and prevents tipping hazards.
- Visual integration: If you want to visually connect the furniture, pay attention to colors, surface textures, and alignment of lines. Additionally, applying cover strips or molding can help conceal transitions and create a harmonious appearance.
- Functionality: Consider the interior fittings and usage to ensure the combination of PLATSA and other furniture remains practical and no disadvantages arise from inconsistent dimensions or fixing points.
It is advisable to measure everything in advance and, if necessary, create a sketch or drawing for the installation.
I hope this clarifies things.
praWarre69
2 Jul 2022 13:26
Hello everyone! 😎
Gugrahame, that sounds like a really exciting project! PLATSA is basically Ikea’s version of modular Tetris – you can do a lot if you’re willing to experiment.
A bit about my experience:
- I once combined my PLATSA units with an old cabinet that wasn’t from Ikea. Tip 1: Clear the floor and test different module arrangements. I found that PLATSA clicks together almost like Lego, but when connecting to non-Ikea furniture, you’ll need screws rather than just clips.
- Use multipurpose brackets (available at hardware stores) installed from the inside so the outside looks clean.
- Visually: If you keep the furniture colors roughly consistent and, for example, swap door handles or use PLATSA accessories, you can create a unified overall look. Don’t hesitate to use matte adhesive film or wooden strips to cover transition areas.
- And last but not least: patience and a sense of humor are essential, especially when a screw doesn’t fit – that’s just part of the process.
Good luck! 😉
NUPIN
3 Jul 2022 07:51
Wow, great questions! 😊 I find it really exciting how much creativity some people put into furniture assembly!
I would recommend:
- Take your time with the planning to avoid unnecessary frustration.
- Especially with PLATSA, it’s very useful to make good use of the included fasteners, but if you want to avoid visible gaps, use very fine trim pieces.
- Don’t be afraid of colors! Even if other furniture is darker or lighter, fresh paint or new handles can tie everything together.
draleo schrieb:
Visual integration: If you want to visually connect furniture, pay attention to colors, surface texture, and the flow of lines. Additionally, applying cover strips or moldings can hide transitions and create visual harmony.
I totally agree with that!
I wish you lots of fun with your project – it’s really rewarding in the end!
Mufato
3 Jul 2022 09:28
For assembly:
- Use screws when connecting different pieces of furniture.
- Attach brackets or metal plates for stabilization.
- Don’t forget wall anchors, especially for heavier loads.
- Use small trim strips or paint on joints for a uniform appearance.
Done.
