ᐅ How can I use IKEA BESTA as a dresser in the bedroom?
Created on: 12 Feb 2021 14:17
Rekabi
Hello everyone, I’m considering using the IKEA Besta system as a dresser in the bedroom. My idea is to use it as a storage solution for clothes and accessories, but I’m unsure about the best way to configure the modules, which types of drawers or doors work best, and what height or depth is practical for a dresser. I’m also interested in how others have designed the Besta as a dresser, especially regarding stability, appearance, and functionality. Do you have any specific tips for planning, possibly suitable fronts or additions to make it look nicer and more practical? I look forward to your experiences and concrete suggestions.
julian36
13 Feb 2021 10:55
Rekabi schrieb:
Can you say something about the design of the fronts – like which is more durable or looks better for a chest of drawers?
Matt lacquered fronts are more resistant to fingerprints, which is convenient for a bedroom. High gloss, on the other hand, makes rooms appear larger but is more prone to scratches and minor damage. Frameless, flat fronts are easier to clean and create a modern look. If you prefer a more classic style, framed fronts are a good choice; they convey sturdiness and can hide surface irregularities. Materials like melamine are durable, while foil fronts may show wear and tear with heavy use.
O
onron
13 Feb 2021 11:48
I would deliberately choose a combination of different surface finishes, for example, matte fronts with individual glass inserts or wood decors; this adds variety and can make the dresser feel more homely. It is also practical if the drawers have soft-close mechanisms. This can be especially helpful at night.
KLONA
14 Feb 2021 09:33
Another aspect to consider is the height of the Besta dresser. Depending on its intended use, it is advisable to aim for a height between 80 and 100 cm (31 and 39 inches) to ensure the surface is practical—for example, for placing clothing or decorations. If you stack several modules on top of each other, make sure to provide sufficient stabilization, such as cross braces or fastening to the wall.
letar
14 Feb 2021 11:27
In addition to the furnished space, you should also consider sufficient air circulation. CLOSE-Front modules can somewhat restrict airflow. You might consider adding small ventilation holes behind the doors or alternatively incorporating open compartments, if the design and use allow it. This helps to prevent moisture buildup in the clothing.
