ᐅ How do I securely attach Ikea Metod kitchen cabinets to drywall (plasterboard)?
Created on: 19 Mar 2024 08:17
Fabrizio45
Good morning everyone, I am planning to mount my Ikea Metod kitchen cabinets on a drywall (gypsum board) wall and want to be on the safe side. The issue is that drywall is relatively soft, and I am concerned whether standard anchors and screws will be sufficient to securely hang the cabinets without them loosening over time or even falling off.
I'm interested in knowing: which mounting methods are reliable and practical for Metod cabinets on an external drywall panel? Do I need to use special anchors, screws, or possibly mounting rails? How can I prevent the cabinets from placing too much load on a wall that is too thin?
What drywall thicknesses does this apply to? How about additional loads from wall cabinets filled with a lot of contents? Are there alternatives such as reinforcing with a substructure or anchoring into the framing behind the drywall?
I look forward to specific experiences and advice, as safety and durability are especially important to me. Thanks in advance!
SONLIS
20 Mar 2024 12:37
Briefly on the difference in detection and procedure:
- Timber studs are generally easier to locate using a classic stud finder, as it reacts to wooden structures.
- Metal studs, on the other hand, require a stud finder with metal detection or a specialized magnet.
Regarding the use of screws:
- For timber studs: wood screws with coarse threads, at least 6 mm (1/4 inch) in diameter and 80 mm (3 1/8 inches) in length.
- For metal studs: self-tapping sheet metal screws, also at least 6 mm (1/4 inch) thick, to ensure a secure hold.
Mounting rails can also be installed afterwards, but in this case, the drywall panel must be at least partially opened or removed to attach the rail to the studs. Sometimes it is possible to mount them over the panel, but only if the mounting points reliably align with the studs and the rail is correspondingly long.
Always ensure that the load-bearing components carry the main load and not just the drywall area!
kieran
20 Mar 2024 13:09
Fabrizio45 schrieb:
Is it possible to install mounting rails afterwards if there is no existing reinforcement?
In cases where mounting rails are added later without prior reinforcement such as an OSB board or similar, it is recommended to secure the mounting rail directly to the studs with screws. This means you need to carefully prepare the drywall in those stud areas to allow the screws to be recessed accurately.
Alternatively, large mounting plates can be attached behind the furniture, fixed to the drywall, to better distribute the load. However, this should be considered a temporary solution, as it does not provide the same level of stability as a direct connection to the structural framework.
Important points to consider:
- Measure and mark precisely.
- Use appropriate screws and wall anchors.
- Ensure even load distribution.
Ultimately, the supporting framework is essential for kitchen furniture. Drywall alone cannot bear significant loads.
LOGEMIN
21 Mar 2024 08:56
Hello everyone, I would like to add a structured guide specifically optimized for installing Metod kitchens on drywall.
1. Preparation:
- Use a 2-in-1 stud finder (wood and metal) to locate and mark the studs.
- Check that the drywall thickness is at least 12.5 mm (0.5 inches).
- If necessary, reinforce with OSB boards or wooden battens if the drywall alone seems too thin.
2. Install the mounting rail:
- Choose a mounting rail made of metal or wood, adjusted to the length of the kitchen units.
- Attach it directly to the studs using strong wood or metal screws (at least 6 x 80 mm (0.24 x 3.15 inches)).
3. Hanging the cabinets:
- Attach the Metod hanging brackets to the mounting rail according to the instructions.
- Level the cabinets and check their alignment.
4. Additional measures:
- For particularly heavy cabinets or intensive use, a further crossbeam can be installed for extra support.
Common mistakes to avoid:
- Relying only on drywall anchors.
- Using screws that are too short.
- Positioning the mounting rail inaccurately.
5. Safety check:
- Apply a test load by pulling on the cabinets.
- Tighten all screws again.
This method allows Ikea Metod kitchen units to be securely and permanently mounted on drywall.
