ᐅ How do I securely attach IKEA Metod kitchen cabinets to different types of walls?
Created on: 21 Aug 2021 18:07
DinoguHello everyone,
I am currently facing the task of securely attaching my new IKEA Metod kitchen to different wall types and wanted to ask for experiences and tips here in the forum. Specifically, I need advice on how to properly fix the cabinets to both solid masonry walls (e.g., brick or concrete) and lighter drywall partitions without compromising stability or causing issues later on.
Which anchors or fasteners are suitable for each wall type? Are the included metal brackets sufficient, or should I take additional measures? Are there any special considerations regarding insulation behind the wall that I should be aware of?
I would appreciate any information on weight limits, mounting techniques, and possibly practical tools (drill, spirit level, etc.).
Best regards!
Best regards!
Dinogu schrieb:
Which anchors or fasteners are suitable in each case? Are the supplied metal brackets sufficient, or should I take additional measures?Hi Dinogu,
first of all: good question! Installing the Metod system isn’t complicated, but the type of wall often makes all the difference. For masonry walls, the original metal brackets with appropriate heavy-duty anchors work great. Concrete anchors or universal wall plugs are best, depending on the type of masonry you have.
Drywall is trickier—you definitely need special cavity anchors or toggle bolts; otherwise, it won’t hold. If possible, use reinforcement plates or backing brackets to better distribute the load.
A hammer drill (for masonry) and a long spirit level are your best friends. And don’t worry about drilling— with the right tools, it’s quick and easy! Good luck, and let us know how it goes! 😉
Hello Dinogu,
I’m happy to add to your question, as I have installed several IKEA Metod kitchens. The fastening method varies greatly depending on the wall type:
- Solid walls (concrete, brick): Anchors like Fischer UX or chemical anchors (for very heavy loads) are suitable here. The supplied metal brackets are usually sufficient, but it’s important to have enough fixing points. Distribute the cabinets well and ensure a level mounting surface.
- Drywall (plasterboard) walls: I don’t recommend using regular anchors here; instead, use cavity anchors such as toggle bolts (Molly bolts) or metal cavity anchors (e.g., Fischer HM). However, these should only be used if the drywall is reinforced with roof battens or a wooden substructure.
Tip: If possible, always try to screw directly into the load-bearing studs behind the wall. Without a substructure, I would be very cautious with drywall.
The weight of the cabinets plus their contents is also important. IKEA Metod can get quite heavy, especially if you store a lot of dishes. Therefore, use multiple fixing points rather than relying solely on the supplied brackets.
Recommended tools:
- Drill with hammer function
- Spirit level
- Screwdriver (manual or electric, but with precision)
I hope this helps you further.
Recommended tools:
- Spirit level
Dinogu schrieb:
Are there any special considerations for insulation behind the wall that need to be taken into account?This is a very important follow-up question, as insulation can significantly affect the fixing method.
For solid walls with external insulation (e.g., polystyrene boards beneath the render), the mechanical load capacity at the fixing level is reduced. In such cases, anchors must be chosen that reach deep into the masonry, not just into the insulation. It is advisable to bridge the insulation at the fixing point and ensure that the screw is anchored in solid material.
In the case of drywall construction, the insulation is often mineral wool or fiberglass within the wall – here, the fixing must not rely solely on the drywall panel. Toggle bolts engage behind the panel, but their load capacity is limited. When mounting heavy wall cabinets, it is recommended to install an additional wooden batten behind the drywall to which the cabinets can be directly fixed.
Another approach is reinforcement with an attached carrier panel (e.g., plywood) as a mounting base, which is screwed into the load-bearing structure and then serves as support for the furniture.
I also advise the following steps:
- Check the wall structure before drilling (using a multi-detector or core drilling)
- Select anchors and screws appropriate for the wall material
- Do not overtighten supplied brackets without additional support in drywall construction
- Accurately calculate loads: 15–20 kg (33–44 lbs) per cabinet door, plus contents
If you provide more detailed information about the wall and existing substructure, I can offer more specific advice.
