ᐅ Securely Installing Ikea Metod Countertops on Different Wall Materials
Created on: 13 Dec 2017 08:17
SinbenHello everyone, I am currently planning to install Ikea Metod countertops in my new kitchen. I need to take into account that the walls are constructed differently: partly solid plaster (brick), one side drywall on wooden studs, and one side concrete.
My main question is how to securely and stably mount the Ikea Metod countertops when fastening to these different wall materials. Which fasteners and installation methods are best suited for each case?
I understand that secure fixing is crucial for the stability of the countertop and the upper cabinets, especially under load from appliances or cutting tasks.
Additionally, I am interested in any special precautions or installation steps to prevent sagging or the risk of the countertop pulling away.
I look forward to your experiences and recommendations.
For solid plaster, I recommend using heavy-duty anchors with matching screws. For drywall panels, be sure to use special drywall anchors or cavity anchors. Concrete walls also require suitable anchors, such as concrete expansion anchors or bolt anchors.
The countertop should always be secured to the wall cabinets, which are ideally mounted on the wall.
For installing Ikea Metod countertops on different wall types, I recommend a multi-step approach:
- On solid plaster (brick): Use heavy-duty anchors (e.g., Fischer UX or Fischer SXR) that provide good grip in the mortar joints. Important: Use the correctly sized drill bit and insert the anchors fully.
- On drywall (plasterboard): Use cavity anchors or metal toggle bolts designed to support the weight of the countertop and kitchen cabinets. Pay attention to the insulation behind the board—if necessary, add reinforcement boards or additional sturdy wooden battens behind the drywall.
- On concrete: Screw-in or impact anchors are best. Pre-drill with a concrete drill bit and secure the anchors properly.
The countertop is primarily supported by the cabinets, which are firmly fixed to wall battens for stability.
It is important to check the countertop support—use additional supports beneath longer countertops to prevent sagging. Silicone joints at seams also provide flexibility.
Are there any more details about the installation site? For example, the expected load, lengths of the countertops, or special cutouts?
deoke schrieb:
Are there any more details about the installation site? For example, the expected load, lengths of the panels, or special cutouts?Thank you for the detailed response. The countertops are approximately 2.4 meters long (7 feet 10 inches) each. The load mainly comes from cutting tasks and occasional placement of heavy appliances like a coffee machine or blender. There is an integrated stove, so there is a cutout for the cooktop.
Since the drywall is supported on both sides by wooden studs, I am considering adding additional cross battens behind the wall to better distribute the load, especially where the panels are fastened.
My question is also whether additional reinforcement under the countertop, for example with slats or metal brackets, is advisable or even necessary at critical points.
Basically, it is advisable to install additional cross battens behind drywall panels to create a sturdy substructure for securing countertops.
Since the countertops will be subjected to loads from appliances and cutting tasks, fastenings should be designed to provide sufficient structural safety.
Reinforcing the countertop with strips or metal brackets can be beneficial at cutout areas (e.g., for a cooktop) and at joints to prevent sagging and warping.
Additionally, it is important to ensure that all fastenings are installed without tension to avoid material deformation.
RETRAVIS schrieb:
Reinforcing the countertop with strips or metal brackets can be useful at areas with cutouts (e.g., cooktop) as well as at joints to prevent sagging and warping.Exactly! I would add that a little attention to detail goes a long way. Custom strips made from plywood or rustic wood can work wonders, providing stability and also looking quite smart. This way, the countertop becomes not only secure but charmingly sturdy! 😉
