ᐅ How can I securely attach IKEA HEMNES shelves to drywall (plasterboard) walls?
Created on: 28 Aug 2017 19:27
ilhan51
ilhan51
28 Aug 2017 19:27
Hello everyone, I am planning to mount several IKEA Hemnes shelves on a drywall partition. Since the walls consist only of gypsum plasterboard without a supporting substructure, I am concerned about how to securely install the shelves so they won’t fall or damage the wall. I am particularly interested in which types of anchors or fixing systems are best suited, whether I should additionally screw the shelves to a possible substructure, or what alternatives exist to ensure the load capacity on drywall. Does anyone have practical experience with safely mounting HEMNES shelves on drywall? What should the maximum load be? I would appreciate any tips and recommendations on suitable materials and procedures.
nixon0
28 Aug 2017 20:13
For drywall, I recommend using special hollow wall anchors, such as metal toggle bolts or spring toggle anchors. It’s best to mount the shelves exactly where wooden or metal studs are located behind the panel. If there is no substructure, hollow wall anchors are the best solution.
V
vinli
29 Aug 2017 08:47
From a technical perspective, the main issue with drywall (gypsum board) walls is the limited load-bearing capacity of the gypsum panels themselves. For HEMNES shelves, which can weigh several kilograms depending on their size and load, it is essential to fixed the mounting points either to the underlying framework (metal or wooden studs) or to use appropriate cavity anchors that distribute the weight more effectively. Recommended are metal expansion anchors, toggle bolts, or special spring toggle anchors that can support at least the maximum combined weight of the shelf and its load. In practice, an allowable load per anchor of approximately 15 to 25 kg (33 to 55 lbs) can be assumed, depending on the type of anchor and panel thickness. For heavy shelves like HEMNES, it is advisable to use multiple fixing points to distribute the load. Pre-drilling should be done carefully to avoid cracking the panel.
difepeo
29 Aug 2017 21:06
vinli schrieb:
From a technical perspective, the main issue with gypsum board walls is the limited load-bearing capacity of the drywall panels themselves.
I agree with that, but I wonder if relying solely on cavity anchors involves more risk than generally assumed. Especially with furniture that is frequently loaded or moved, fatigue can occur.
On the other hand, it’s not always possible to access behind the drywall or to precisely locate the studs. Does anyone know proven methods to detect the studs either visibly or at suitable points? Is a simple stud finder sufficient for this?
Also: Do adhesive mounting foam or special heavy-duty adhesives play a supplementary or alternative role? Or are these generally unsuitable for securing furniture?
Rosstar
30 Aug 2017 10:52
difepeo schrieb:
Does anyone know proven methods to locate studs visibly or at appropriate points?
Yes, for detecting metal or wooden studs behind drywall, so-called stud finders or metal detectors are used, which reliably indicate metal. Additionally, you can carefully probe with a narrow nail to locate wooden studs.
difepeo schrieb:
Do adhesive mounting foam or special heavy-duty adhesives play a complementary or alternative role?
No, I do not recommend using adhesives to fix HEMNES shelves on drywall. The mechanical stress from the weight and load of the shelves requires secure screw fastening with appropriate anchors designed for tension and shear forces. Mounting adhesive can only serve as additional support but does not replace anchors.
In principle, I recommend: locate the substructure and fasten there. If this is not possible, use high-quality metal toggle anchors with the appropriate load capacity certification, distribute the fastening points, and avoid overloading the shelf.
