ᐅ Which tools do I need to disassemble IKEA Hemnes furniture?
Created on: 31 Jul 2024 08:13
prafu
Hello everyone, I am planning to dismantle my IKEA Hemnes wardrobe and would like to know in advance which tools are absolutely necessary for this. It is the classic Hemnes model, usually assembled with common fasteners like dowels and screws. Since I prefer not to buy multiple tools, it would be great if you could provide me with a comprehensive list of tools I will need to safely take the wardrobe apart without causing any damage. Which screwdrivers, special tools, or possible aids are essential for an easy dismantling? Thanks in advance for your advice!
benon
31 Jul 2024 09:20
Marcellela schrieb:
A Phillips screwdriver (PH2) and a 4mm (0.16 inch) Allen key are usually all you need. This is pretty standard with Hemnes.
That’s true, but sometimes there are clips or small metal fasteners used – in those cases, a small flathead screwdriver usually helps, especially when you need to pry off back panels made of thin wood or hardboard.
prafu
31 Jul 2024 09:31
Thank you very much for the quick and helpful answers! One more follow-up question: In the cabinet carcass, there are often these metal cam connectors that you turn with a screwdriver – does it matter if the screwdriver is small or large? And is there anything I should watch out for to avoid damaging or crushing the connectors?
Jensson
31 Jul 2024 09:47
prafu schrieb:
In the carcass, there are often these metal cam connectors that you turn with a screwdriver – does it matter if the screwdriver is small or large?
Good question. For the cam locks in Hemnes, it’s best to use a properly sized Phillips PH2 screwdriver that matches the screw size – not too small, so you don’t round off the recesses in the metal. However, a screwdriver that’s too large can also get stuck if it doesn’t fit well.
prafu schrieb:
And do I need to watch out for anything to avoid damaging or crushing the connectors?
Yes, definitely turn carefully and avoid using force. If a connector won’t loosen, check again if you might need to press parts together or lift slightly. Never use excessive force or impact tools. Being too rough can damage cam locks, which is frustrating when reassembling.
warrenka57
31 Jul 2024 09:59
I understand that this can be a bit frustrating, especially when you're unsure which tool to use. I had the same experience with a Hemnes wardrobe and was glad to find helpful tips in forums that encouraged me. If something gets stuck, just take a break and try again calmly. Good luck!
KLO-KA
31 Jul 2024 10:12
A small tip: If you have a screw that won’t turn, try using some WD-40 or a similar penetrating oil. It can sometimes help. However, don’t use too much and apply it only to the moving parts.
Greglau
31 Jul 2024 10:25
Everything already mentioned, plus: Take your time and sort the screws by type and size immediately during removal. Pry tools can be used carefully, but not for destructive purposes. Good tools save a lot of frustration.
