ᐅ What to do if Ikea Hemnes shelves are not level?
Created on: 3 Aug 2024 09:12
O
onboso
I recently set up several shelves from the Hemnes series by Ikea in my home. I noticed that some of the shelves are not standing completely straight, even though I placed them on what appears to be a level floor. The issue affects both their vertical alignment and stability. Now I’m wondering what could be causing this tilt and how to effectively fix it.
I understand that uneven floors can play a role, but the problem seems a bit more complex because even slightly adjusted shelves don’t remain stable and straight over time. Are there proven methods to keep Hemnes shelves perfectly upright permanently? Should special tools or accessories be used? Or is it necessary to modify the shelves themselves, for example by readjusting screws or adding reinforcements?
Maybe someone has experienced this problem and can share tips on how to avoid it permanently. Thanks for your help!
Maria35
3 Aug 2024 13:25
The discussion already shows that there is rarely a single cause. My recommendation would therefore be:
- Measure the floor using a digital spirit level or a precise measuring device.
- If unevenness of up to about 5 mm (0.2 inches) is present, furniture glides or custom-made wooden wedges can help.
- Pay close attention to careful assembly – the shelving unit must fit flush at all screw connections.
- Especially with Hemnes shelves, the back panel provides cross-bracing, so it should not be omitted.
If all of this is done and the shelf still does not stand straight, consider securing the shelf to the wall with special brackets to ensure stability and proper alignment.
TEOZAR
3 Aug 2024 16:48
If you are new to Hemnes shelves or unsure about the assembly, here are some simple and easy-to-follow tips:
- Always start by carefully studying the assembly instructions and checking all components.
- Use plastic or wooden shims to level the shelf. These can be easily placed under the feet to compensate for minor unevenness in the floor.
- Don’t forget the back panel, as it acts like a brace and helps keep the unit straight.
- If the floor is uneven and there is enough space, placing a thin rubber mat around the shelf can provide additional stability.
In general: Patience when adjusting is crucial. Making screw-by-screw adjustments step-by-step usually leads to success.
Elijah42
3 Aug 2024 18:06
One more brief addition:
If the shelf still wobbles after all adjustments, be sure to secure it to the wall. Hemnes shelves have fixing points for this purpose.
Additionally, if the floor is very uneven, felt or plastic furniture pads are a good choice to ensure stability.
Lorukeo
4 Aug 2024 08:03
Josefane schrieb:
I have not seen this statement confirmed as such. The Hemnes shelf is very simply designed; to my knowledge, adjustable feet are not standard.
That’s correct, my wording was unclear. Hemnes does not actually have adjustable feet, but as mentioned, washers can be placed under the feet for fine adjustment. This is common practice for shelves without built-in adjustability.
Furthermore, I want to emphasize that when correcting unevenness, caution is necessary to avoid unevenly distributing heavy loads, as this can put stress on the structure.
Dilen
4 Aug 2024 09:34
Here are a few notes on wall mounting and back panel stability that are often overlooked:
The back panel of the Hemnes shelving unit is usually made of thin, non-solid material that can warp under uneven load. Its primary purpose is not to bear weight but to reinforce the structure against tipping. Stabilizing the back panel with additional brackets or screws positively affects the overall straightness.
Wall mounting is typically done using wall plugs (anchors) and appropriate screws, which is highly recommended for taller shelves to ensure tip resistance.
In summary:
- Secure the back panel properly
- Use washers to compensate for uneven floors
- Install wall mounting
Feel free to share how your floor is laid and whether you have already installed wall mounts.
Jensson
5 Aug 2024 07:52
One more practical guide to finishing:
- Check your floor not only with a spirit level but also with long straight edges or rails to detect any waves.
- For slight unevenness: place small plastic wedges under the feet of the shelf.
- During assembly: tighten the connecting fittings firmly to avoid stress in the wood.
- Align the back panel precisely and check it before final screwing.
- After installation, if any tilt is detected, secure the shelf to the wall with appropriate angle brackets.
This will help you achieve a permanent straight alignment.
