ᐅ How can I secure IKEA BESTA furniture to prevent it from tipping over in a home with small children?
Created on: 20 Apr 2022 18:23
Abidin
Abidin
20 Apr 2022 18:23
Hello everyone, I recently purchased several IKEA BESTÅ furniture units for our living room and installed them. Since we have small children in the household, I’m very concerned that these units might tip over if the kids climb on them or pull on them. My goal is to secure the BESTÅ furniture against tipping as safely as possible without compromising the design or having to carry out extensive modifications.
Can anyone with experience or expertise offer advice on the best way to do this? I would like to know what safety measures IKEA itself recommends, which accessories could be additionally purchased, and how to ideally anchor the furniture to the wall. Tips on special anti-tip legs or base frames would also be helpful.
I’m also interested in alternative solutions, for example, anti-tip straps that can be added. What should be particularly considered when using this furniture in a home with children? I look forward to a detailed discussion and shared experiences. Thanks in advance!
KINMIN4
20 Apr 2022 20:07
The most important thing is to always securely attach the BESTÅ furniture to the wall using the supplied wall fixtures.
Additionally, you can use anti-tip straps, which are often available as a set at hardware stores.
Replacing the legs or using other accessories is less effective; wall mounting is mandatory.
gilen
21 Apr 2022 08:13
Hello Abidin, I completely understand your concerns, especially when there are small children in the home—secure fastening is essential. IKEA BESTÅ furniture usually comes with wall attachment kits designed to prevent tipping. You should definitely use these and mount the furniture to solid wall surfaces, meaning not just drywall panels but ideally near wall studs or concrete walls.
In addition to wall mounting, there are several other measures you can take to improve safety:
- Anti-tip straps or screw-in safety belts that secure the furniture at the top
- Non-slip rubber pads under the feet to increase stability
- Avoid placing heavy loads on top or stacking items high, which can add extra stress or instability
I also recommend checking the furniture regularly to ensure it remains firmly secured and always encouraging children not to climb on the furniture.
If you like, I can send you detailed assembly instructions—they help a lot. Better safe than sorry!
BAUEVA
22 Apr 2022 14:46
gilen schrieb:
IKEA BESTÅ furniture usually comes with so-called wall-mounting kits to prevent tipping.
That is correct, but I consider this alone insufficient, especially with small children. The standard IKEA wall anchors use simple screws and plugs, which are not always strong enough to resist high tipping forces.
You should also check the type of wall the furniture is installed on. Above drywall many anchors perform poorly – in such cases, I recommend special metal anchor screws or more robust fastening systems.
gilen schrieb:
Non-slip rubber pads under the legs to improve stability
I find this ineffective in preventing tipping, as the tipping moment usually causes the front legs to lift off the floor and lose contact with the wall.
My suggestions:
- Do not compromise on wall mounting; use screws with high load capacity
- Place furniture in room corners, where stabilizing walls support on both sides
- Additionally, use a plumb line or spirit level to ensure the BESTÅ cabinet is perfectly vertical
Above all, do not rely solely on the supplied accessories; carefully assess the on-site conditions and expected loads.
