ᐅ How can I safely install IKEA Metod wall cabinets on older building walls?
Created on: 26 Apr 2021 09:17
Q
QUINNDEO
I am planning to install several IKEA Metod wall cabinets in my old apartment. I am unsure how to securely fix the cabinets to the typically somewhat unstable walls found in older buildings. Most of my walls are made of old masonry, partly covered with drywall, and I feel that conventional wall plugs do not provide enough support.
Does anyone have experience with securely mounting Metod wall cabinets on such walls? Specifically, I am interested in:
- Which fixing materials are best suited for masonry walls in older buildings?
- Are there any special techniques or preparation steps I should consider?
- How should I deal with walls that are partially uneven or crumbly?
I would be very grateful for any tips, personal experiences, or suggestions for ensuring a safe installation. My main concern is that the cabinets hang securely and permanently, without damaging the wall or risking the cabinets falling down.
QUINNDEO
Elias
27 Apr 2021 09:55
I understand your concerns, especially with older buildings and small differences in wall structure. I’ve faced similar challenges in my own apartment.
The advice to use a mounting panel is definitely the right approach because it distributes the load evenly. If you’re unsure about estimating the weight yourself: a single Metod wall cabinet usually weighs around 20-25 kg (44-55 lbs). With contents like dishes, glasses, etc., it can easily reach 30-40 kg (66-88 lbs) per cabinet.
When you connect several cabinets, the weight adds up quickly. So for 2-3 cabinets, you should definitely expect a total weight between 70 and 120 kg (154-265 lbs).
This is manageable if the fastenings are correct. If you have any doubts, take them seriously and consider hiring a carpenter or tradesperson if you don’t feel confident doing it yourself.
sarGabriel
27 Apr 2021 12:27
Mounting boards or a wooden batten fixed horizontally on the wall are often the best choice. Use heavy-duty anchors and always measure with a spirit level. Secure cabinets individually, then assemble them to avoid stress at a single point.
boelnu
27 Apr 2021 18:05
Elias schrieb:
If you connect multiple cabinets, the weight adds up quickly. Therefore, you should definitely expect a total weight between 70 and 120 kilograms (155 and 265 pounds) for 2-3 cabinets.
It reassures me that I’m not the only one worried about this. I faced similar issues and worked with mounting plates. By the way, I always planned for two to three fixing points per cabinet as a precaution to distribute the load.
Also: Always check that the drill holes in the masonry are cleanly made, because otherwise the force is concentrated on a small area, which can cause damage to the wall over time.
Gregory
28 Apr 2021 08:39
Regarding mounting panels, I would like to add that the material used and its thickness are very important. An 18 mm (0.7 inch) thick plywood panel is highly suitable. It should be secured with heavy-duty anchors at least at three to four points.
After that, you can hang the wall cabinets on the mounting panel using the original Method hangers. This creates a secure system with good load distribution.
Another advantage is that you can easily remove the cabinets later without stressing the wall each time.
If you are unsure, I recommend discussing the use of a mounting panel with a structural engineer or a skilled tradesperson.
