ᐅ How do I replace a broken back panel in a BILLY bookshelf?
Created on: 31 Jul 2021 19:08
pemeo54
Hello everyone, unfortunately, the back panel of my IKEA Billy bookcase got damaged. Over time, it developed some small cracks, and now a larger section has actually broken. My question is how to best replace the back panel of a Billy bookcase without having to completely disassemble the entire unit.
I assume the back panel is only nailed or stapled in place, but I don’t want to start pulling it off recklessly and risk damaging the cabinet frame. Are there any proven methods or tips for safely removing the back panel and then either cutting a replacement panel myself or using a suitable replacement from IKEA? What kind of tools should I definitely have on hand, and is there anything specific I should pay attention to so that the bookcase remains stable once it’s reassembled?
I would appreciate it if someone could share their detailed experience, including any alternatives to the original back panel or small repair options. Thanks in advance!
pemeo54
2 Aug 2021 08:27
Domau0 schrieb:
How old is your BILLY cabinet?
The cabinet is about 7 years old. The back panel is made of a relatively thin, simple fiberboard. In my opinion, it is not reinforced with metal. The break is at a lower corner; it probably happened because the back panel expanded or shifted under tension due to varying humidity levels in the room.
Thanks for the tips about chamfering and light sanding—I didn’t know that. I’ll go to the hardware store soon to get brackets and nails and make sure to align the cabinet properly. I will probably have the panel cut myself, as I can’t get original replacement parts here.
The idea of laying the cabinet on its back really makes sense and should make the work easier—I was considering disassembling it, but I’d like to avoid that.
One last question: Is there a typical thickness or size for back panels that IKEA usually uses, so I can order the right panel at the hardware store?
