ᐅ How do I repair cracked surfaces on IKEA PLATSA units?
Created on: 18 Dec 2021 09:37
Minken
Minken
18 Dec 2021 09:37
I recently discovered a torn surface on one of the doors of my IKEA Platsa wardrobe. The surface is made of a coated particleboard, which seems to have torn along an edge. My question is, what is the best way to repair this torn surface without significantly affecting the appearance or compromising stability? Are there specific adhesives, fillers, or surface repair kits recommended for this?
It is also important to me whether the damage can be repaired without completely replacing the front panel, and what the best procedure would be – such as cleaning, preparation, gluing, etc. What about sanding or repainting if necessary? I would appreciate concrete tips and experiences, as I would like to do the repair myself but am not familiar with the materials and the process.
plopra
18 Dec 2021 10:05
I would recommend first gluing the crack with an appropriate wood glue. Then smooth it with fine sandpaper and, if needed, touch it up with a repair pen for laminate or furniture foil. This way, you won’t need to replace the fronts.
Palenar
18 Dec 2021 11:42
Minken, to give you a truly sustainable repair recommendation, I would need to know the exact size of the crack and whether the surface is actually peeling off or just cracked.
Basically, I recommend the following procedure:
- Carefully clean the crack with a fine blade or scalpel (remove dust, loose fibers)
- When opening the crack, apply a small amount of wood glue or a special waterproof contact adhesive inside the crack with a thin brush
- Use a small, preferably pointed spatula or plastic blade to spread the glue inside the crack and immediately remove any excess glue
- Use clamps or weights to close the crack while drying (at least 12 hours)
- After drying, gently smooth with very fine sandpaper (grit 320-400)
- Apply a color-matched furniture repair paste or scratch repair marker (preferably gently blend with a cosmetic sponge or soft cloth)
It is important not to use glue with too high a water content, as the chipboard underneath can swell. Alternatively, special repair kits from the hardware store designed for veneered or laminated surfaces can be used; please make sure they are suitable for PLATSA materials, otherwise color or surface texture may not match.
Feel free to describe your crack in more detail or if the chipboard has been damaged.
Rashadmeo
18 Dec 2021 12:15
Hey Minken, great that you’re tackling this yourself! 😊 I had a similar issue with my PLATSA doors and fixed it using a special repair kit for wood laminate. Super easy!
The key is to avoid applying too much pressure when gluing, otherwise it will crack again. And if you sand the crack smoothly and then touch it up with a matching pen, it becomes barely noticeable.
Don’t get discouraged, you’ll manage! 👍
Friedrich
19 Dec 2021 08:23
Minken, I understand that this is a frustrating damage, especially with the nice PLATSA furniture, which otherwise looks quite sturdy. I personally once had some concerns about whether a crack in a cabinet front would hold at all.
Rashadmeo schrieb:
It is really important not to apply too much pressure when gluing, otherwise it will crack again.
That’s true, I would add that having patience during the drying phase really helps. After repairing, I could hardly see the crack anymore. If you like, I can also share some tips on how to match the color tone perfectly – I used a special wax for that.
Please keep us updated on how things go for you!
FRANCISCOP
19 Dec 2021 14:17
Here are some factual notes for clarification:
- The material of the PLATSA fronts should be regarded as coated particleboard, typically melamine-coated. Therefore, liquid penetration is problematic and should be avoided.
- For repairs, waterproof wood glues or solvent-based contact adhesives that do not expand excessively are suitable.
- Sanding should be done with very fine sandpaper to avoid further damaging the surface.
- For visual touch-ups, furniture repair kits are available, often containing wax or marker components that can be color-matched.
A complete replacement of the fronts is only recommended for major damage; otherwise, careful gluing and finishing repairs are usually sufficient.
