ᐅ How do I repair cracked surfaces on IKEA PLATSA units?
Created on: 18 Dec 2021 09:37
Minken
I recently discovered a torn surface on one of the doors of my IKEA Platsa wardrobe. The surface is made of a coated particleboard, which seems to have torn along an edge. My question is, what is the best way to repair this torn surface without significantly affecting the appearance or compromising stability? Are there specific adhesives, fillers, or surface repair kits recommended for this?
It is also important to me whether the damage can be repaired without completely replacing the front panel, and what the best procedure would be – such as cleaning, preparation, gluing, etc. What about sanding or repainting if necessary? I would appreciate concrete tips and experiences, as I would like to do the repair myself but am not familiar with the materials and the process.
enrique7
20 Dec 2021 10:49
A technical note: In my opinion, it is important to consider why this crack occurred in the first place. Was it due to material fatigue, swelling caused by moisture, or stress from improper installation?
Depending on the cause, a simple repair might only be a short-term solution. If moisture is involved, the crack could reappear, and the damage may worsen.
Furthermore, if the area is frequently used, mechanical stresses should also be taken into account during the repair. A professional repair kit with impregnation or sealing might provide a longer-lasting result.
Have you ever treated your Platsa furniture preventively to avoid such damage?
