ᐅ Are there any recommendations for using solid wood furniture instead of particleboard with Ikea PLATSA?
Created on: 20 Mar 2024 09:27
sijatar
Good morning everyone,
I recently came across the Ikea Platsa system and am considering using it for my storage solution. However, I am bothered by the use of particleboard in most components, as I prefer solid wood for stability and environmental reasons.
Does anyone have recommendations or experience with solid wood furniture that is compatible with PLATSA, or perhaps retrofit solid wood components for PLATSA?
I would like to know if the quality and durability of solid wood really offer advantages here, or if I have to accept compromises, for example in terms of weight, price, or ease of handling.
I appreciate any insights, especially if you have already combined solid wood furniture with PLATSA or know where to find such alternative solutions.
Thank you in advance!
In addition to the previous posts:
If you decide to replace parts of the PLATSA system with solid wood, I would keep the following in mind:
- Measurement accuracy: The dimensions of the connection points and drill holes are precise specifications from Ikea, so replacement parts fit properly. A custom-made solid wood piece must be accurate to the millimeter.
- Warping considerations: Solid wood can warp, especially if it is not sufficiently dried or exposed to varying humidity. Particleboard hardly warps.
- Connection techniques: Particleboard handles screws less well than solid wood, but the PLATSA connection system (dowels, cam connectors) is specifically designed for particleboard. You might be able to tighten screws more loosely on solid wood without damaging the material.
Question: Would it be feasible to make only the visible surfaces from solid wood and leave the load-bearing parts as particleboard? This reduces effort and risk.
I’m also happy to offer advice on how to proceed when replicating individual parts.
Dilen schrieb:
Question: Would it be feasible to use solid wood only on the visible surfaces and leave the load-bearing parts as particleboard? This way you reduce effort and risk.Yes, that was my plan from the beginning: to keep the base components (side panels, bottom parts, etc.) and especially make the fronts, doors, shelves, and trims from solid wood. For the doors, I was thinking of using thinner solid wood or beech plywood, since that is lighter.
I also plan to modify the wall cabinets so that I don't increase the weight too much.
What is the best way to properly finish the wood surface when using it in living spaces? I want to avoid lacquer and too many chemicals, but the wood surface still needs to be protected from dirt and moisture. Does anyone have recommendations?
For the surface treatment of solid wood, I recommend the following options:
- Hard wax oil: penetrates deeply into the wood, protects against moisture and dirt without sealing the surface.
- Natural resin oil: similar to hard wax oil, provides the wood with a pleasant tactile feel.
- Water-based varnishes: offer very good protection but can be more visually pronounced and may alter the tactile sensation.
For interior living spaces, hard wax oils are often the best compromise between protection and a natural feel. It is important to maintain the surface regularly.
Regarding installation: also ensure that the wood moisture content is ideally between 8-12% before processing to minimize warping.
In addition to the topic of stability in solid wood panels:
Screw connections usually hold better in solid wood than in particle boards, provided the screws are properly chosen (length, diameter, thread type). Screws in particle boards can loosen more easily if they are repeatedly tightened and loosened.
Plywood can be a good alternative, as it combines the visual and mechanical advantages of solid wood with better dimensional stability.
Summary:
- Solid wood for fronts and visible elements
- Plywood as a technical solution for shelves and seating surfaces
This is a good compromise between appearance, function, and sustainability.
Summary:
