I have a question about repairing scratches or dents on IKEA Platsa furniture. The PLATSA series mainly consists of coated wood-based panels with edges made of melamine or foil, which can make repairs somewhat tricky. I am especially interested in the best way to fix small to medium scratches or dents without causing uneven surfaces or noticeable color differences.
Are there practical methods that can be easily done at home without having to replace entire furniture parts?
I am interested in tips on preparing the damaged area, suitable materials (e.g., special fillers or markers), and the final treatment step (e.g., sealing or smoothing).
If there are differences depending on the various surface types of the PLATSA series, that information would also be helpful.
Looking forward to your suggestions!
Hello sobugi,
First of all, an important note before you start the repair: Depending on the severity and depth of the scratch or dent, the approach may vary, so it is worth determining the type of damage as accurately as possible.
PLATSA usually consists of particleboard with a melamine resin coating, which provides a smooth and hard surface but is barely sandable. Small scratches can generally be repaired with so-called furniture repair wax sticks. These are available in colors close to the common IKEA shades. Important here is to
- carefully clean and dry the area beforehand,
- apply the stick only thinly,
- gently remove excess material with a fine plastic spatula,
- then let it dry for about 1 day,
and possibly lightly abrade the surface with a fine sanding pad (very fine grit, 600 or higher) if the surface appears too glossy or uneven.
Dents are more difficult. If the coating is not damaged, you can try to raise the dent using a damp cloth and an iron (steam method). Place the cloth over the dent, then briefly apply the iron at medium temperature and use the steam to expand the particleboard.
If the surface is cracked, however, this method won’t help, since the coating is gone and you have to work with fillers, for example repair putty specifically for wood-based materials. These are applied, sanded, and then treated with a matching color. Make sure the putty fits well to the surface dimensions and is not applied too thickly, otherwise the difference will be noticeable.
Lastly, it is recommended to seal or protect the repaired spot with clear lacquer or furniture wax to stabilize it.
How severe is the damage in your case exactly? Are the coatings still intact, or is the particleboard exposed? Do you already have suitable repair materials at home? If you can tell me this precisely, I can assist you more specifically.
Regards!
Regards!
JAMESONB4121 Feb 2021 11:37Hello sobugi,
for minor scratches, you can use furniture repair markers or wax crayons in IKEA colors.
For dents, steam treatment with a damp cloth and an iron often helps.
If the surface is damaged, use wood filler and then apply matching paint.
JAMESONB41 schrieb:
Dents can often be treated with steam using a damp cloth and an iron.That almost seems like magic, doesn’t it? But seriously, the steam method only works on wood panels as long as the surface coating hasn’t become brittle. Steam won’t fix the coating; it’s more likely to damage it.
The common advice to just fix it with markers or household hacks often just partially hides the spots, and the furniture ends up looking worse. My tip: it’s better to invest in high-quality repair kits with color matching and the necessary tools—otherwise, you’ll end up with problems and noticeable color differences.
Also, why mess around with repairs at home? IKEA PLATSA is modular and relatively affordable. If the damage is too big, it’s better to replace the affected door or side panel. This also gives a fresher overall appearance than halfhearted repairs.
Just a thought against the frequent notion here that “only repairing” is the right solution.
