ᐅ How can I protect the surface when painting IKEA PLATSA myself?
Created on: 21 Feb 2024 08:12
Enverjo
Hello everyone, I am planning to paint my IKEA Platsa furniture myself, but I have concerns about how to best protect the surface without the paint peeling off or creating unattractive spots. The surface of the Platsa units is quite smooth and appears to be painted or treated, which might make it difficult for the paint to adhere.
I am especially interested in:
- What kind of surface preparation is generally recommended (sanding, priming, etc.)?
- Are there specific protective coatings or sealants I should use to protect the furniture from moisture and wear?
- Are certain types of paint better suited for Platsa surfaces?
I want to do this as durable and cleanly as possible. Thanks in advance for your tips and experiences!
MOMIRA
22 Feb 2024 08:22
When applying the paint, work in well-ventilated areas and avoid dust particles. Dust can easily stick to fresh paint and cause an uneven surface.
Proper sanding before priming and between coats ensures smooth surfaces and better protection.
KUDAISY
22 Feb 2024 09:15
Joe52 schrieb:
The protection only develops after complete curing – this can take up to 2 weeks.
Exactly, that’s an important point! The final hardness of the paint film often develops only after several days to weeks. You should take this into account when using the furniture.
Enverjo schrieb:
Which clear coat would you recommend that is resistant to scratches and moisture?
Also, a note on finish: Matte or glossy? Matte finishes are significantly more sensitive to stains and wear. Glossy clear coats are usually more durable.
Summary for optimal protection:
- Proper preparation (light sanding, cleaning)
- Primer for smooth surfaces
- 2-3 coats of paint, allowing drying and sanding between coats
- 2-3 coats of PU clear coat, preferably semi-matte or glossy
- Patience during drying and curing
Enverjo
22 Feb 2024 11:48
Thank you all for the help and clear advice!
Here is a summary of my to-do list:
- Light sanding with 240-320 grit
- Cleaning with denatured alcohol
- Primer specifically designed for melamine foil
- 2-3 coats of acrylic or polyurethane (PU) paint with intermediate sanding
- 2-3 coats of PU clear coat (preferably glossy)
- At least 12 hours drying time between each coat, preferably longer
- Only subject furniture to heavy use after full curing (up to 2 weeks)
If anyone has additional suggestions, feel free to share. Otherwise, I will start the project soon and may report back with my experience.
Fitigu
22 Feb 2024 14:10
That sounds like a solid plan. Just one addition:
When applying the primer and paint, it’s best to use a dust-binding surface or ensure a workspace that is as dust-free as possible. The surface greatly benefits from a clean application.
Good luck!
