ᐅ How can I protect the surface when painting IKEA PLATSA myself?
Created on: 21 Feb 2024 08:12
Enverjo
Hello everyone, I am planning to paint my IKEA Platsa furniture myself, but I have concerns about how to best protect the surface without the paint peeling off or creating unattractive spots. The surface of the Platsa units is quite smooth and appears to be painted or treated, which might make it difficult for the paint to adhere.
I am especially interested in:
- What kind of surface preparation is generally recommended (sanding, priming, etc.)?
- Are there specific protective coatings or sealants I should use to protect the furniture from moisture and wear?
- Are certain types of paint better suited for Platsa surfaces?
I want to do this as durable and cleanly as possible. Thanks in advance for your tips and experiences!
Enverjo schrieb:
How long should each layer (primer, paint, sealer) ideally be allowed to dry for optimal protection?In practice:
- Primer: at least 12 hours, preferably 24 hours, to fully cure.
- Paint layers: 6 to 12 hours between coats, depending on the paint and product instructions.
- Clear coat: also 12 hours for optimal hardness.
Enverjo schrieb:
Is sanding between layers necessary?Yes, definitely always do a very light sanding between multiple paint layers using 320-400 grit sandpaper. This significantly improves adhesion of the next layer.
Enverjo schrieb:
If I use a blocking primer for the base coat, how strong should it be, and are there ones specifically recommended for melamine or foil surfaces?Make sure to use an adhesion-promoting blocking primer, not a standard wood primer. It should be specially formulated for smooth surfaces, such as an acrylic blocking primer or a specialized plastic primer. Adhesion is the key factor, not just opacity.
Great, thanks, that helps me a lot.
One more question: What about protection against mechanical stress?
The furniture will be used regularly on a daily basis. Which clear varnish would you recommend that is resistant to scratches and moisture? Are there differences between clear varnishes that should be considered?
And how many coats are recommended to build a durable protective layer?
Regarding mechanical durability, I can contribute the following:
- Clear coats based on polyurethane (PU coatings) generally offer better scratch resistance and moisture protection than pure acrylic coatings.
- Two-component (2K) PU coatings are particularly durable but require experience in mixing and application.
- For hobby users, high-quality one-component (1K) PU clear coats are a good alternative and easier to apply.
- At least 2–3 layers of clear coat are recommended. Each layer should be applied thinly and fully dried, and intermediate sanding should not be forgotten.
Important: On surfaces subject to heavy use, professional painting or at least a tested multi-layer coating with PU clear coat is advisable. Also, pay attention to the product information regarding abrasion resistance.
Hello Enverjo, I really appreciate how much thought you’re putting into this!
I had a similar project about a year ago. My advice: patience is key, especially when painting and, most importantly, during drying. At the beginning, I applied the layers too quickly, which affected the final finish somewhat.
Also, try not to move the furniture around too much right after painting. The protective surface only fully develops after complete curing – which can take up to 2 weeks.
I understand your desire for a durable finish, but I’ve found that too much effort isn’t necessarily better when you’re a beginner. It’s better to do less, but do it well.
