ᐅ How can I protect IKEA PLATSA from scratches caused by pets?
Created on: 16 Feb 2020 09:47
Jameo2
Jameo2
16 Feb 2020 09:47
I recently assembled an IKEA Platsa shelving unit and am very pleased with the system’s flexibility and appearance. However, I have an issue that some of you might be familiar with: my cat keeps scratching the surface of the cabinet doors, causing visible scratches.
I am now looking for effective ways to protect my IKEA Platsa from pet scratches. I am especially interested in durable, practical solutions that do not significantly affect the look of the furniture and are relatively easy to implement.
Does anyone know of protective surface coatings, films, or other tips to preserve the fronts? It would also be helpful to learn whether the material or construction of the Platsa is particularly suitable or unsuitable for such protective measures.
I look forward to concrete advice and experiences.
Z
zartra
16 Feb 2020 10:52
To prevent scratches on the IKEA PLATSA caused by pets, you can apply a transparent protective film to the surfaces.
Alternatively, furniture edge protectors or scratch guard strips made of plastic, which can be attached directly to the door panels, are also effective.
Regularly trimming your pets’ nails also reduces the risk of damage.
Surela
17 Feb 2020 14:23
Regarding protecting the IKEA PLATSA shelf from scratches caused by cats or other pets, I would recommend a multi-step approach. First, it is important to consider the specific material construction of the fronts: the PLATSA doors are usually made of melamine-coated engineered wood, which is durable but not immune to deep scratches.
As an initial protective measure, a clear, scratch-resistant vinyl film can be applied, cut precisely to fit the door dimensions. These films have high abrasion resistance and are easy to apply and remove without damaging the surface. It is important to thoroughly clean the surface before application to avoid air bubbles.
If your cat frequently scratches the fronts, you might also place scratching boards or scratching posts nearby to redirect attention. This also serves as prevention and helps relieve your furniture.
Technically, a polyurethane-based protective coating is possible, but it is usually more complex and requires touch-ups, as it can alter the material.
Have you checked if your pets also scratch other pieces of furniture? Depending on the behavior, comprehensive training or the use of certain deterrent sprays might be advisable. What type of pet do you have exactly? That would help to refine the recommendations.
KAMERON
18 Feb 2020 08:15
Surela schrieb:
Regarding protecting the IKEA PLATSA shelving unit from scratches caused by cats or other pets, I would recommend a multi-layered approach.
Surela’s analysis hits the mark: a combination of physical protection and behavior modification is the most effective.
Additionally, I would like to point out that when selecting protective films, UV resistance should be considered to prevent yellowing after a short time. Films with anti-slip properties are also advisable to reduce slipping during cat claw activity.
Another practical option is attaching magnetic protective plates that can be easily removed when needed. These are particularly gentle on the original surfaces and offer flexible handling.
Regarding surface protection, it should be noted that applying lacquer sealants is generally not recommended as a DIY method on melamine-coated surfaces, as they neither adhere properly nor provide a lasting protective layer.
If the furniture is placed in an area favored by pets, it is also worth considering targeted environmental changes to help minimize unwanted scratching.
