ᐅ How can I protect Ikea Pax wardrobes from everyday scratches?
Created on: 29 Oct 2019 07:13
ransford
ransford
29 Oct 2019 07:13
Hello everyone, I have owned the Ikea PAX wardrobe for several months now, which offers me a lot of storage space and looks good. However, I have noticed that with everyday use, many small scratches and signs of wear appear, which quickly make the otherwise nice piece of furniture look old and unattractive. Therefore, my question to you is: How can I effectively protect my Ikea PAX wardrobe from scratches in daily use without reducing its practical functionality or appearance? Are there any specific materials, care instructions, or tips you would recommend? I am very much looking forward to your detailed advice and experiences.
anno58
29 Oct 2019 08:51
Hello ransford, your concern is completely understandable and affects many who use the PAX wardrobe. To avoid scratches, I recommend first cleaning the surface regularly with a soft, slightly damp cloth to remove dust and dirt, which are often the cause of fine scratches. An important tip is to apply furniture glides or felt pads to high-use areas, especially if you frequently open doors or drawers or touch the wardrobe with objects. Transparent, self-adhesive protective films can also be applied easily without affecting the design. Also, be careful not to place sharp objects directly on the surface. Silicone-free care products for laminated surfaces help keep the surface smooth and reduce susceptibility to scratches. If you like, I can provide some product names that have proven effective.
semuneo
29 Oct 2019 14:37
anno58 schrieb:
Also, be careful not to place sharp objects directly on the surfaces.
This is definitely an issue that has caused me problems repeatedly. I often handled bags, keys, or slippery items on my PAX, which led to small scratches despite being careful. Since I started using small felt pads on the surfaces inside and outside, I feel more confident and notice less wear. It is also important to be cautious when placing and arranging items in the wardrobe to avoid anything catching or scraping. I think it’s often a combination of careful handling and systematic protection.
JUHAU
29 Oct 2019 16:24
The best solution is a transparent protective film. You apply it to high-impact areas to prevent scratches. Additionally, use furniture sliders on the bottom of the doors. Done.
miAlessio
30 Oct 2019 10:03
To protect your Ikea PAX from scratches, here is a brief guide:
- Step 1: Cleaning – Dust and sand particles are the main causes of scratches. Always clean with a microfiber cloth and a mild detergent free of harsh chemicals.
- Step 2: Apply protective films – There are transparent, self-adhesive protective films that can be cut to size. These should definitely be silicone-free to prevent stickiness or discoloration.
- Step 3: Use felt pads – At all contact points, such as doors or drawers, felt pads help prevent abrasion marks.
- Step 4: Avoid sharp objects – Items like keys, metal parts, or sharp-edged tools should not be placed directly on the surface.
- Step 5: Regular maintenance – Once a month, applying special care oils for painted surfaces can keep the material supple.
Common mistakes include using overly aggressive cleaners or neglecting protective films. If possible, I also recommend adding edge profiles or narrow protectors, especially on exposed cabinet edges.
U
usbla
1 Nov 2019 09:12
As an addition: Ikea PAX wardrobes are often made from melamine-coated particleboard, which is durable but can develop scratches under localized or repeated pressure and mechanical stress. A recommended method to reduce scratches is applying protective films with self-healing properties, similar to those used for laminate or wooden surfaces in furniture. These films act as a transparent barrier and can repair minor scratches through heat.
Furthermore, consistently using felt pads under decorations, electronic devices, or other heavy items is essential. A common issue occurs from dirt picked up on shoes or clothing, which can cause unnoticed scuff marks on the side panels when opening the doors. A narrow protective edge or a rubber edge guard can help prevent this.
It is also advisable to close the wardrobes gently rather than slamming them shut. Mechanical door dampers, such as soft-close hinges, can help prevent scratches caused by doors being closed abruptly.
