ᐅ How can I protect Ikea BESTA furniture from moisture in a basement?
Created on: 23 Jan 2021 08:17
LekunuHello everyone, I plan to assemble some Ikea Besta furniture in the basement to create additional storage space. However, since we occasionally experience moisture issues in the basement, I’m concerned about how to effectively protect the BESTA furniture from moisture damage.
I am especially interested in practical measures or proven techniques suitable for furniture made of coated MDF like the BESTA. Are there specific sealants, spacers, or other precautions that can minimize the impact of moisture? Has anyone had experience with this furniture in basement environments and can offer tips on protecting it from rising damp or condensation-related moisture?
I look forward to your well-informed answers and advice, including any important points to watch out for in order to prevent damage or warping over the long term.
Good question! 🙂 I would definitely make sure that the BESTA cabinets are not placed directly on cold, damp concrete. If necessary, put them on some wooden battens or even on Euro pallets – this allows better air circulation, and your furniture will thank you.
Oh, and a dehumidifier is a little hero in the basement that is often underestimated. It adds a bit of drying magic. 😄
Basically, BESTA furniture is quite sensitive to moisture because of its coated MDF panels.
The following points are crucial:
- Never place furniture directly on the floor to prevent rising moisture.
- Use special spacers or substructures made of plastic or wood, maintaining a distance of at least 2-3 cm (1-1¼ inches) from the floor.
- Regularly monitor the indoor humidity, ideally between 40% and 60%.
- If possible, use dehumidifiers or improve ventilation.
- Additionally, impregnating the untreated edges with wood preservative can help reduce moisture absorption.
These protective measures primarily aim to prevent damage caused by swelling and mold growth.
roryvin schrieb:
If possible, use dehumidifiers or improve the ventilation.Dehumidifiers are certainly useful, but I wonder whether it might be more effective to consider structural measures in advance.
- How is the basement generally waterproofed?
- Are there damp walls or floors that could increase the risk to furniture over time?
Protecting furniture only makes sense if the actual source of moisture is addressed. Additionally, I would question how effective sealing MDF surfaces really is, since often the coating itself is not very water-resistant. Replacing them with more suitable furniture types for damp storage areas can sometimes be the more cost-effective solution.
Linavin schrieb:
Protecting furniture only makes sense if the actual source of moisture is addressed.That’s a very important point, thank you! Our basement is generally dry, but on cold days, condensation sometimes forms on the walls, causing the floor to become slightly damp. A complete renovation for waterproofing is currently not planned or would be too extensive.
So, I’m mainly looking for practical solutions that can be implemented without major construction work. So far, I like the idea of using underlays or spacers.
Jodyro schrieb:
Regularly ventilate the basement to reduce moisture.How exactly do you manage this? Daily short ventilation? And for how long? Of course, I want to avoid the furniture getting unnecessarily cold or absorbing even more moisture.
