ᐅ How can I protect Ikea BESTA furniture from moisture in a basement?
Created on: 23 Jan 2021 08:17
Lekunu
Hello everyone, I plan to assemble some Ikea Besta furniture in the basement to create additional storage space. However, since we occasionally experience moisture issues in the basement, I’m concerned about how to effectively protect the BESTA furniture from moisture damage.
I am especially interested in practical measures or proven techniques suitable for furniture made of coated MDF like the BESTA. Are there specific sealants, spacers, or other precautions that can minimize the impact of moisture? Has anyone had experience with this furniture in basement environments and can offer tips on protecting it from rising damp or condensation-related moisture?
I look forward to your well-informed answers and advice, including any important points to watch out for in order to prevent damage or warping over the long term.
tangi
24 Jan 2021 07:47
Regarding moisture protection in basements, I recommend the following approach:
- Cross-ventilation is advisable, ideally several times a day for 5-10 minutes, to reduce humidity levels. Avoid continuous ventilation, as this would lower the air temperature too much.
- Use furniture pads or spacers under the Besta furniture series to prevent direct contact with the cold floor.
- In cases of direct moisture exposure, moisture absorbers (e.g., granulate in containers) and dehumidifiers can be helpful.
- When assembling furniture, ensure it is slightly spaced away from the walls to allow air circulation and prevent direct damage from condensation.
These measures are proven in practice and effectively reduce the risk of moisture-related damage.
praWarre69
24 Jan 2021 09:19
I’ll add a bit of casual advice 😉:
I placed my BESTA furniture in the basement on wooden slats – not only does it look better than plastic coasters, but it also creates a small gap from the “cold ground” below.
My tip: treat the edges with microporous silicone spray; it doesn’t absorb too much moisture and protects the wood.
And listen to your basement – if it murmurs too damply, ventilate, and if it screams, use a dehumidifier. That way, your furniture stays happy, and so do you!
GALENKU
25 Jan 2021 10:02
Summary:
- No direct contact between furniture and damp basement floor
- Regular airing out by fully opening windows, 3 times a day for about 5 minutes
- Use dehumidifiers whenever possible
- Treat furniture edges with wood preservative
- Install furniture with a gap from the wall
This should provide the BESTA furniture with adequate protection against moisture.
