I recently bought a Billy bookshelf to use for books and some decorative items. However, I have two lively cats who are incredibly curious and like to scratch or climb on furniture. Now I’m worried that they might damage the shelf, whether through scratch marks, tipping it over, or other wear and tear.
So my question is: How can I effectively protect my BILLY shelves from damage caused by pets like cats or dogs? Are there any specific protective measures you would recommend? For example, I’m considering whether the shelf can be treated with protective films or special varnishes, or if it’s better to use mechanical protective devices instead.
I look forward to your tips, experiences, and possible instructions!
Thank you in advance!
Hello Denzo,
I find your question very interesting because the topic of furniture and pets involves many important nuances, especially when dealing with cats that use their claws very deliberately, but also dogs that are more likely to cause damage through movement and play.
A proven approach is first to understand which types of damage occur most frequently: with cats, these are usually scratch marks on edges or surfaces. A BILLY shelf made of particleboard is relatively vulnerable, especially if it has a clear varnish. One option is to re-treat the surface with a durable, transparent protective coating. You should look for a scratch-resistant but environmentally friendly acrylic varnish that seals the wood without changing the character of the shelf.
At the same time, I recommend mechanical barriers: scratch protection films are indeed an option; they are transparent and protect against sharp mechanical scratches. Alternatively, you can attach special furniture edge protectors made of plastic or fabric on exposed corners and edges, for example on the lower shelves that are more easily accessible to cats.
Another consideration that is often underestimated is distracting the animals. Provide your cats with good scratching options such as scratching posts or sisal poles so they use those instead of the shelf. It might even be advisable to temporarily shield the furniture or rearrange the room.
May I ask how old your cats are and how active they are? This will give me a better idea of whether you should expect minor wear or really need intense protection.
Denzo, I agree with Laukau5’s thoughts and would add that you should also consider regular maintenance. For example, after cleaning the surface, you can apply a furniture polish with conditioning ingredients. While it won’t protect against scratches, it will make the surface more durable and easier to clean.
Additionally, when you have dogs, the movement space in front of the shelving unit should be minimized to avoid repositioning that could cause it to tip over. If your pets are very playful, securely anchoring the shelving unit to the wall is recommended to prevent it from falling.
If you want to use protective films with an active mechanism, make sure the films are free of harmful substances and that the adhesion is not too aggressive, so the material of the shelving unit is not damaged.
The suggestion to use scratching posts is also good, but you should ensure they are maintained regularly and truly provide an appealing alternative.
Laukau5 schrieb:
A proven approach is to first understand which types of damage occur most frequentlyHonestly, I find that a very conservative approach. I mean, you can keep applying varnishes or sticking on protective films, but if you ignore the nature of the animals, the problem will remain. Cats naturally scratch and want to do so, especially in higher places.
Wouldn’t it make more sense to redesign the shelf to make it less accessible or less appealing? Perhaps by covering parts entirely with decorative fabric or leather, which cats find less attractive? Or you could modify the shelf with extra elements specifically designed for the cats, creating a combination of furniture and cat playground.
I often see this handled too one-sidedly – either protecting the furniture or banning the cats. Why not adjust both sides to create a real solution?
Hello Denzo,
I completely understand your concern and would like to share some practical advice from my experience. A good way to protect BILLY shelves from cat damage, which I often recommend, is to cover the shelves with transparent, wipeable plastic sheets that can be easily cut to size.
These sheets protect the surfaces, are easy to clean, and cats usually quickly realize that they are not suitable for climbing or scratching. It is important to secure the corners well to prevent slipping and avoid sharp edges.
Additionally, I suggest applying a final protective layer with a special furniture wax after cleaning – this makes the surface more durable and gives it a nice shine. Your idea of using protective varnishes can also work, but make sure it is non-toxic in case your feline friends lick it.
If you like, I can also provide some sources for the materials needed or more detailed tips on how to apply them.
Hi Denzo,
wow, this is a topic that really excites me! I love cats and also the design of BILLY shelves – but you are absolutely right, the combination can be tricky.
What worked really well for us is a combination of distraction and protection: we installed corner protectors made of soft silicone at the most vulnerable spots. They are almost invisible and provide great protection. At the same time, we offer the cats plenty of scratching options nearby, so they lose interest in the shelf itself.
And hey, I even used small, thin furniture films – of course matte black, because it matches our living room and is discreet. It really prevents scratches, and applying it is actually fun 🙂
Give it a try! I’m really curious to see what you come up with – and I’m keeping my fingers crossed that your furry friends adjust to the shelf! 😊
