ᐅ How do I properly clean the surface of Ikea PLATSA?
Created on: 16 Apr 2022 09:17
Tanemily
Tanemily
16 Apr 2022 09:17
Hello everyone, I recently bought an Ikea Platsa shelving system and am now looking for a gentle yet effective way to properly clean the surface. Since the furniture is made of coated material, I want to avoid damaging the finish or leaving unsightly streaks.
I am especially interested in which cleaning products you would recommend, whether it is better to avoid household remedies like vinegar or citric acid, and how often the cleaning should ideally be done to prevent the surfaces from becoming dull or porous.
It would also be helpful to know if specific cleaning techniques or tools (for example, microfiber cloths versus sponges) are better suited for removing dust and stains without damaging the surface.
I look forward to your practical tips and experiences!
naujon
16 Apr 2022 11:43
Hello Tanemily, a few months ago I researched a similar topic and can offer you a structured approach:
- First, I generally recommend cleaning with a soft, slightly damp microfiber cloth, as this material does not cause scratches and efficiently picks up dust.
- Avoid aggressive cleaning agents or highly acidic solutions (such as vinegar or citric acid), as these can damage the coating and cause dullness over time.
- For normal dirt, a mild soap solution (for example, a pH-neutral dishwashing detergent dilution) is perfectly sufficient.
- It is important to wipe the furniture dry with a dry cloth after cleaning to avoid water spots or streaks.
I consider cleaning every two weeks reasonable to remove dust and light dirt on time without unnecessarily stressing the surface.
Common mistakes include using abrasive cleaners or scouring pads that damage the surface. Also, never use too much water, as standing moisture can harm the surface.
Timmyse36
16 Apr 2022 14:22
Interesting question, I really appreciate how thoroughly you described the issue, Tanemily!
naujon schrieb:
- Avoid aggressive cleaning agents or strongly acidic solutions (such as vinegar or citric acid), as these can damage the coating and cause it to become dull over time.
That matches my experience as well. I once tried to remove a stain with vinegar, and unfortunately it left a lighter spot that only faded after several weeks. Since then, I only use microfiber cloths and very gentle cleaners.
Sometimes cleaning makes me a bit nervous because I’m afraid of damaging the surface, but I think if you follow the guidelines, it works out fine.
Thanks also to naujon for the very helpful tips!
Siflo
17 Apr 2022 09:05
For additional information and an objective summary:
Ikea PLATSA furniture usually has a melamine coating or similar surfaces that are sensitive to abrasive cleaners and strong acids.
- Using neutral cleaning agents with a pH close to 7 is ideal.
- Microfiber cloths are recommended, as they clean gently without causing scratches.
- Avoid sponges with rough surfaces.
- Always wipe in circular motions without applying excessive pressure.
- Prevent prolonged exposure to water or cleaning agents to avoid swelling of the edges.
In conclusion: The surface should be left dry and streak-free after cleaning.
These guidelines generally apply to delicate furniture surfaces and are specifically suited to the PLATSA system.
noge58
18 Apr 2022 12:37
Hey Tanemily and everyone else!
I think it’s great that you’re thinking so carefully about cleaning PLATSA furniture; it shows how much you value your furniture. 😊
At home, I often just use lukewarm water with a drop of mild dish soap and a soft microfiber cloth.
Since I started treating my furniture this way, they’ve looked great and I no longer worry about stains. No fuss, but very effective!
Keep it up, your furniture will thank you! 👍
