ᐅ How do I properly clean Billy bookcases to remove stubborn stains?
Created on: 2 Sep 2022 08:37
PadaliHello everyone,
I have a question regarding the cleaning of my Billy shelves from Ikea. Specifically, it concerns stubborn stains that cannot be removed with standard cleaning products. The shelves have a white laminated surface, and of course, I do not want to damage it.
Does anyone have experience with the best way to treat such stains? Which cleaning agents or methods are suitable to protect the surface while effectively cleaning it?
I look forward to your tips and advice!
Regarding cleaning Billy shelves with white laminate surfaces:
First, it is important to avoid aggressive cleaners, as they can damage and fade the surface. A good approach is:
1. Gently clean with warm water and a mild dish soap.
2. For stains that do not come off, you can use a mixture of water and a few drops of vinegar. Vinegar acts as a mild disinfectant and can dissolve some organic residues.
3. Use a soft microfiber cloth to prevent scratches.
4. For stubborn stains, a stationery eraser may help—test carefully in an inconspicuous area first.
Additionally: Never use abrasive pads or harsh chemicals like acetone, as they will dissolve the laminate.
Summary: Use gentle agents, handle carefully, and always test in an inconspicuous spot.
I can fully understand how frustrating stains on Billy shelves can be. I experienced something similar and wasn’t sure what I could use without damaging the surface. It really helps to be patient and always test small areas first.
I have also used a slightly damp microfiber cloth with a few drops of neutral soap that contains no harmful additives. I carefully rubbed and gradually removed the stains. It is also important not to use too much moisture, as this can cause the edges to swell.
If you like, I can share a few other products I have tested.
Guyju schrieb:
An eraser from office supplies can sometimes help with stubborn stainsThanks for this tip, that sounds really interesting. Could it work on paint or felt-tip pen stains?
JAFUHAU schrieb:
Patience is important and testing small areasI agree, especially with furniture that has special finishes, I’m afraid of unsightly stains caused by incorrect cleaning.
Does anyone perhaps know of specific cleaning products that Ikea itself recommends for these shelves? Or is it generally better to stick to home remedies?
