ᐅ How do I properly clean Billy bookshelves to remove grease stains?
Created on: 22 Aug 2020 12:37
Elek41Hello everyone,
I recently noticed that my Billy shelves have some smudge marks in certain areas. These are typical signs of use, likely grease or paint residues, which cannot be easily removed with a damp cloth. Naturally, I want to avoid damaging the melamine surface or affecting the color quality by using overly aggressive cleaning agents.
My specific question is: How can I properly clean Billy shelves to remove smudge marks without damaging the material? Are there proven methods or particular cleaning products that work well? Any advice on suitable cleaning techniques, appropriate amounts of cleaning agents, and things to avoid would be very helpful.
Thank you in advance for your help!
Hello Elek41,
First of all, this is a great topic that concerns many people. I have a method that has proven effective for stains on melamine surfaces:
1. Start by removing any loose dirt with a soft, dry cloth.
2. Then I recommend mixing lukewarm water with a drop of mild dish soap. Always apply sparingly to avoid soaking the material.
3. Gently work on the stains using a soft sponge or microfiber cloth in circular motions.
4. If that’s not enough, you can carefully apply a small amount of rubbing alcohol, but do not rub—just lightly dab.
5. Finally, wipe with a damp cloth and allow to dry thoroughly.
Tips:
- Never use abrasive cleaners or rough sponges, as they will scratch the surface.
- Avoid cleaning in direct sunlight to prevent further staining.
If the stains are very stubborn, there are also specialized cleaning pastes for melamine, but these should be tested cautiously.
I hope this helps you!
Tips:
LOJOPAR schrieb:
If that is not enough, you can carefully apply a small dab of denatured alcoholHi Elek41, just to emphasize this with a wink: denatured alcohol is the little magician for smudge marks on Billy shelves 😉 But please, as LOJOPAR already said, don’t be too rough – otherwise, the shelf will look like it’s been bombed after cleaning.
You can also try gently rubbing the stains with an eraser. It sounds strange, but it really makes sense for smaller smudges and is completely gentle on the material!
Good luck and maybe even some fun in the battle against the stains :-)
Elek41 schrieb:
How can I properly clean Billy shelves when they have smudge marks, without damaging the material?To answer this question, it is important to correctly identify the surface of the Billy shelves. The shelves have a melamine resin coating, which is durable but can be damaged if treated improperly.
Smudge marks are usually caused by grease-based residues or pens. The recommended approach is:
- Use a microfiber cloth that is slightly dampened to gently work on the stain.
- If necessary, use a solution of water with a few drops of dish soap, as this does not damage the surface.
- For stubborn stains, isopropyl alcohol (not acetone) can be applied carefully and locally.
- Avoid cleaning sprays containing solvents or abrasive cleaners.
Using a rubber eraser-like area is indeed a gentle physical method that does not require solvents.
Finally, dry the cleaned areas to prevent water marks.
This method ensures cleaning without causing surface damage.
Katan schrieb:
Gently rubbing a pencil eraser over the stains. Sounds strange, but it really works for small smudges.I would like to critically examine this recommendation from an analytical perspective: Is a standard pencil eraser really safe for a melamine resin coating? The abrasion caused by rubber could create microscopically fine damage on sensitive surfaces, which may dull the finish over time.
Therefore, in my opinion, when using mechanical methods, one should always weigh the short-term benefit against potential long-term damage.
Are there any reliable studies or practical experiences confirming the harmlessness of the eraser trick? Or would it be preferable to use mild solvents that act quickly?
A well-founded argument would be helpful to avoid unnecessary damage to the furniture while achieving effective cleaning.
