ᐅ How do I plan the installation of Ikea Metod power strips in the kitchen?
Created on: 24 Nov 2015 09:12
JAKLA
JAKLA
24 Nov 2015 09:12
I am currently planning the installation of Ikea Metod power strips in my kitchen and want to approach the planning carefully so that everything fits properly and is safe. Specifically, I am facing the challenge of installing multiple power strips in the base cabinets and possibly also in the wall cabinets, without creating cable clutter or safety issues with the electrical supply.
My questions include:
- What is the best way to measure the required lengths of the power strips and cables?
- Are there any specific limitations when installing in the Metod kitchen modules, such as interior dimensions or mounting options?
- What should I particularly consider from an electrical safety perspective, especially when connecting multiple power strips in series?
- Which tools and materials are recommended for the installation?
I have done some research but have found varying information. It would be great if someone with practical experience could share tips to help me complete the project without unpleasant surprises.
Thanks in advance!
erikpu
24 Nov 2015 09:57
Hello JAKLA,
Initially, I would recommend measuring the internal dimensions of the Metod base cabinets carefully. The Ikea power strips are usually modular but can only be cut or adjusted up to a certain length. Make sure the power strip does not directly affect any heat sources inside tight cabinets.
When measuring the cables, always include some extra length to allow enough slack for connection and positioning. Also, keep in mind the location of the wall outlet so you don’t end up with cables that are too short or too long.
From an electrical standpoint, it is important never to connect multiple power strips in series. Each power strip should be plugged directly into a wall outlet to avoid overload. I would also recommend allowing some space around the installation to enable heat dissipation.
As for tools: a cordless drill with metal and wood drill bits, a voltage tester before working on the main power supply, cable ties for tidy cable management, and possibly cable ducts can be helpful.
If you have more precise measurements or photos, it will be easier to provide better assistance, but this should give you a basic idea to start with.
putan
24 Nov 2015 10:14
JAKLA schrieb:
Specifically, I am facing the challenge of installing several power strips in the base cabinets and possibly also in the wall cabinets, without creating cable clutter or any issues with the power supply.
Hi JAKLA, that’s what makes it interesting! 😄 My advice: make a sketch showing where you want each power strip, so you can better estimate the cable lengths.
And don’t worry about the power cords: with cable clips and zip ties, you can keep everything very tidy and it will look almost professional in the end. Also, since Ikea tends to prefer modular setups, you can use that approach for the power strips as well.
The most important thing, as erikpu says, is to avoid daisy-chaining power strips, otherwise the circuit breaker might get overloaded quickly.
Good luck!
eldubi
24 Nov 2015 10:36
I would suggest:
- Connect all power strips directly to a wall outlet
- Measure internal dimensions and adjust the strips on site
- Use metal brackets or screws for mounting
- Neatly bundle cables, avoiding sharp bends
This will help you avoid the most common mistakes.
kla65
25 Nov 2015 08:19
One more quick tip: Check if your power strips have mounting options, such as holes for screws. Don’t just lay them down, as this could become dangerous if the cabinets move. Safety comes first.
ixlu1
25 Nov 2015 12:41
Hey JAKLA, your planning idea is great! 👍 Once you have a plan and note down all the measurements including the positions of the electrical outlets, the installation will go smoothly.
Don’t forget: especially in the kitchen, outlets are often intended for high-power appliances (kettle, blender, etc.), so it’s better to plan with some extra capacity for power consumption. If you size the power strips properly and use circuit breakers where possible, everything will be safe.
And: have fun with the installation! Such a project is really enjoyable when you design everything yourself!
