ᐅ How do I plan IKEA PAX wardrobes for use in rental apartments?
Created on: 9 May 2023 18:37
goranron6
goranron6
9 May 2023 18:37
I am planning to use the Ikea PAX wardrobe for my new rental apartment, but I am unsure about the best way to approach this. Especially in rental properties, there are often restrictions such as not being allowed to drill holes in the walls or having limited space, and I want to make the wardrobe as flexible, stable, and visually appealing as possible.
My questions are:
- Which planning steps are particularly important when customizing PAX systems for rental apartments?
- Are there any experiences with mounting the wardrobe without drilling into the walls?
- How can the different modules be assembled to be easily disassembled yet still load-bearing?
I would also appreciate tips on optimizing storage space, especially in small rooms, and advice on which PAX elements are best suited.
Thank you in advance!
SONLIS
9 May 2023 20:14
Hello goranron6,
First of all, I think it’s great that you are considering the framework conditions—especially the prohibition of drilling holes in rental apartments—in your planning. This is indeed a key factor when designing PAX systems in a rental setting.
A few suggestions from my experience:
- For fastening without drilling holes, it’s advisable to rely on weight and gravity instead. PAX frames are relatively stable when filled with suitable interior fittings, but they should still be secured to the wall to minimize tipping hazards. There are clamping systems available that can be wedged between the floor and ceiling.
- The ease of disassembly depends heavily on the chosen interior layout. Drawers and clothes rails are easy to remove, so look for modular components that can be taken out quickly.
- Cam connectors are useful because they provide a firm hold without visible screws.
To optimize storage space, I recommend positioning the PAX units in the corners of the room and utilizing the space up to the ceiling—that creates a lot of volume.
Best regards!
Jeanbar
10 May 2023 08:53
Hello goranron6,
I’d like to add some points since you’re asking for tips on proper planning and the challenges in rental apartments:
- First, you should carefully measure the room and enter the exact dimensions into the Ikea PAX planner. This is very helpful for avoiding wrong purchases.
- For rental apartments, many people are bothered by visible drill holes. Therefore, special wall mounts that use clamping or tension systems are recommended.
SONLIS schrieb:
- When fixing without drill holes, it is advisable to rely on weight and gravity instead.
Exactly, this method is well-tested. However, you should make sure that the wardrobe is still stable and won’t tip over. Some creative solutions include metal profiles or spacers that are attached to the back of the furniture.
Also, when planning, feel free to use the PAX software down to the finest detail. Besides width, height, and depth, you should also consider the door opening direction and interior organization.
Finally, one tip: it might be useful to make a list beforehand of the items you want to store. This way, you can better decide whether you need more drawers, clothes rails, or shelves.
Good luck!
kaubi
10 May 2023 14:26
Hello goranron6,
your question shows a good approach, so I’d like to go deeper into the topic, especially since PAX units in rental apartments bring some technical challenges.
First, regarding attachment: In rental apartments, drilling is usually prohibited, and there are often restrictions on the load-bearing capacity of floors or ceilings. Apart from the mentioned clamp systems, you should use high-quality anti-tip fittings that either use a clamping mechanism or friction to secure the wardrobe against tipping. Ikea normally supplies anti-tip fittings for PAX that attach to the wall and wardrobe; here, I would seek a compromise, such as adhesive or plug connectors that leave no visible holes.
The ability to disassemble depends on your interior design: full-extension drawers and shelves are easy to remove anyway, and for hanging rails, I recommend metal profiles that can also be hung without screws. It is also advisable to use adjustable components that can be height-adjusted to make the wardrobe flexible for different requirements.
It is also important to measure the room very precisely and watch out for any baseboards, radiators, or windows—accurate planning with the PAX planner is indispensable here. In addition, you can partially omit the back panels or modify them with thinner materials if the room depth is limited.
Jeanbar schrieb:
- For rental apartments: Many people are bothered by visible drill holes.
An important point: Not only drill holes but also visible cables or connectors should be avoided to maintain aesthetics. Interior lighting is still a good option if you consider cable channels or USB-based LED systems.
Finally, a small tip: If you have lightweight walls (drywall), be a bit more cautious. Especially heavy or wide PAX carcasses can seem unstable if they are fixed only from above. In this case, the weight distribution and fitting the unit into niches are crucial.
If you’d like, you can share your room dimensions, and then we can address your situation more precisely.
Best regards!
