ᐅ How can I optimize the installation of Ikea Metod cabinets on uneven walls?
Created on: 12 Sep 2020 18:47
Casparpra
Casparpra
12 Sep 2020 18:47
I am about to start a project installing Ikea Metod kitchen cabinets on a wall at my home that unfortunately is not completely flat. My wall has visible irregularities, especially in the lower section, which makes aligning the cabinets quite challenging. I want to do this securely and in an aesthetically pleasing way, without ending up with gaps or unsightly spaces.
Do you have any experience or proven methods for mounting IKEA Metod cabinets on uneven walls? What tools or techniques do you use to ensure the cabinets are still installed flush and stable?
In particular, I’m interested in:
- How exactly do you deal with wall unevenness? Do you fill and smooth the wall beforehand, or do you use special mounting systems?
- Are there clever adjustments to the cabinets themselves, for example with the legs or brackets?
- What tools or additional materials would you recommend for a durable and neat installation?
Thank you in advance for your tips and experiences!
Danial
12 Sep 2020 19:12
Casparpra schrieb:
Do you have any experience or proven methods for installing IKEA Metod cabinets on such uneven walls?
The main question with uneven walls is how large the deviations actually are. If they are minor, it is certainly possible to work with adjustable feet and mounting rails. For more significant unevenness, the wall should be skim-coated beforehand or leveled with mounting panels (e.g., OSB or drywall) to create a flat surface.
Casparpra schrieb:
Do you apply skim-coating first, or do you use special mounting systems?
Skim-coating provides the most stable long-term solution but is labor-intensive. Alternatively, mounting brackets and adjustable wall mounts can help align the cabinets. I recommend using a spirit level and laser measuring device to ensure everything stays truly level.
Any other approach that simply tries to ignore wall unevenness often leads to stress within the furniture and eventually to damage.
LAGUDO
12 Sep 2020 19:45
In my experience, wooden battens placed behind the cabinets work very well to even out irregularities. Simply attach battens of the appropriate thickness to the wall, then hang the cabinets on them. This way, you have a level support surface.
BOSULE
13 Sep 2020 08:23
An important note regarding uneven walls: Ikea Metod cabinets are generally designed to be adjusted for floor irregularities using the adjustable feet. However, for wall unevenness, it is crucial to accurately align the mounting rail or bracket first.
I recommend the following approach:
- First, use a long spirit level to check where the wall actually deviates.
- Compensate for unevenness using spacers or shims.
- Secure the mounting rail, then hang the individual cabinets on it and adjust them optimally.
If possible, fill larger indentations or bulges beforehand with suitable filler materials to ensure additional support. Important: Cabinets should not be forced or wedged between uneven areas, as this can stress the structure.
Jeanbar
13 Sep 2020 10:05
Hello Casparpra,
I had a similar situation recently and solved the installation like this: First, I treated the wall areas that were very uneven with repair filler. Then I fixed a plywood board of appropriate thickness to the wall using construction adhesive and screws. This board was precisely aligned and created a flat surface.
The Metod cabinets could then be perfectly secured to this. I was able to use the adjustable feet to level the carcasses exactly horizontally and plumb. This also ensured the doors were flush later and could be adjusted easily.
Tools I found particularly helpful:
- Spirit level (at least 80 cm (31 inches) long)
- Laser level
- Cordless drill
- Putty knife and sandpaper
- Measuring tape and pencil for markings
This method takes a bit of time but provides a stable and visually flawless result.
Danial
13 Sep 2020 13:44
Jeanbar schrieb:
First, I treated the particularly uneven wall areas with repair filler.
That is exactly the initial point.
I wonder how well a repair filler holds up in kitchen areas, especially when subjected to stresses from temperature changes and moisture. Does anyone have specific experience with the long-term durability of such fillers?
Also: There are systems with adjustable mounting profiles. In your opinion, are these underused without good reason, or are they simply too many tools and steps for the DIY builder? I believe a practical solution would be desirable here.
