ᐅ How can I optimize storage space in IKEA Metod tall cabinets?
Created on: 31 Dec 2021 09:37
PekotuHello everyone,
I am currently planning our new kitchen, focusing specifically on optimizing storage space in IKEA Metod tall cabinets. Since these cabinets are quite deep and tall, I would like to know the best ways to make the most of the interior space. I am especially interested in clever organizing methods that fully utilize the available space, as well as which IKEA accessories are truly useful for this purpose.
I am also curious if there are any recommended alternatives or additions to IKEA accessories that are compatible with Metod, to store smaller kitchen utensils, pantry items, or larger objects in an organized yet easily accessible way.
Additionally, it would be helpful to learn from other users’ experiences regarding storage design in these tall cabinets, such as load capacity of the shelves or the optimal use of niches and gaps inside the cabinets.
In short: How can I optimize storage in IKEA Metod tall cabinets to maximize capacity while keeping the setup practical and user-friendly? I look forward to your tips and suggestions!
Regarding space optimization in IKEA Metod tall cabinets, there are several technical aspects to consider.
A common mistake is to install only fixed shelves. Given the cabinet height (up to 240 cm (94 inches)), it is easy to create multiple levels, but that alone is not sufficient. Interior drawers and pull-out shelves (e.g., Maximera or Veddinge) are particularly recommended, as they significantly improve access to deep spaces.
It is important to adjust the shelf heights flexibly, as universal drilled holes allow this. This way, tall or differently sized items can be stored easily. Most shelves have a weight capacity of about 15-25 kg (33-55 lbs), which should be considered especially for heavy pots.
As a supplement, additional solutions such as inner door racks and storage baskets can be used, which are mounted on the inside of the doors. Sorting inserts are suitable there for smaller utensils.
Alternative accessories from third-party providers are often compatible if they conform to the standard dimensions; however, I recommend IKEA accessories due to their precise fit.
Thank you for mentioning your question regarding compartmentalization; however, I have a follow-up question: What cabinet height and what type of items do you mainly want to store in the cabinets? This greatly influences the optimal layout.
kulau schrieb:
Thanks for mentioning your question about dividing the space. I do have a follow-up: What cabinet height and types of items do you mainly want to store in the cabinets? This greatly affects the ideal layout.Thanks for asking, kulau! Our tall cabinets are 240 cm (94 inches) high and 60 cm (24 inches) deep. We primarily want to store pantry goods (canned food, flour, sugar, etc.), as well as kitchen utensils, pots, and larger baking pans. Some boxes with dry goods should also fit.
It’s important to me that the individual shelves are adjustable and can accommodate different item sizes. The design should allow easy access, especially to the deeper areas. Good visibility and quick reach of all items are essential since we spend a lot of time in the kitchen and don’t want to waste time searching.
Perhaps this points to an ideal layout or combination of fixed shelves, pull-out drawers, and possibly door solutions?
Hello Pekotu,
Your description has already addressed some key points. The combination of adjustable fixed shelves for light storage boxes and larger items with deep pull-out drawers for pots and baking trays is ideal.
I recommend
- installing at least two to three pull-outs at mid-height, so you can make optimal use of the depth without having to reach around to the back.
- using fixed shelves at the top and bottom that are flexibly height-adjustable.
- fitting the inside of the doors with door-mounted racks for spices or smaller utensils.
For better organization, you can use sorting inserts and transparent boxes; this helps keep things tidy. Another tip: avoid placing shelves too close to each other, as this reduces flexibility for items of different sizes.
The load capacity of Metod shelves, as kulau already mentioned, is around 15–25 kg (33–55 lbs). For very heavy items, a pull-out drawer can be sturdier. Also, pull-outs offer better access, especially in deeper cabinets.
In summary: flexibility through height adjustment and dividing cabinets into pull-outs and fixed shelves, complemented by door solutions for smaller items.
I recommend
In addition to the previous input, I would like to highlight the following:
The interior layout of the Metod tall cabinets greatly benefits from a well-considered mix of pull-out drawers and traditional shelves. In particular, the 'Maximera' drawers are sturdy and glide very smoothly; they can also be complemented with inner organizers. This allows for organized storage of spices, small boxes, or rolls of foil, for example.
For very tall cabinets, it is helpful to divide the storage space into two main sections: the lower part for heavy and larger items, such as pots, as is often the actual use, and the upper part for lighter, less frequently used supplies. Ideally, these should have sturdy shelves.
Using door organizer systems on the inside of cabinet doors provides additional space, for instance for baking paper, foil, or small bottles.
Note that a depth of 60 cm (24 inches) means not all pull-outs utilize the full depth—practical layouts take into account accessibility to the back areas.
As a final tip: always plan about 5 cm (2 inches) of clearance above and below the shelves—otherwise, unexpected issues may arise when removing the pull-outs.
