ᐅ How can I best install IKEA PLATSA furniture in sloped ceilings?
Created on: 14 Aug 2019 08:23
Teo-je51
Teo-je51
14 Aug 2019 08:23
I want to furnish my attic apartment with IKEA Platsa furniture and am facing the challenge of integrating it optimally into the sloped ceiling. My main concern is how to best plan and install the PLATSA series so that it effectively utilizes the room height and angles of the pitched roof while ensuring a stable and durable construction.
The following points are particularly important to me:
- What is the best way to measure the slope, taking typical deviations into account?
- Are there useful modifications or additional elements such as special shelves or custom fittings?
- How can I securely attach the units, especially on slanted walls, without major structural changes?
- Is it possible to combine several modules to maximize storage space?
- What should I pay attention to during final assembly, especially on uneven floors or ceiling slopes?
What experiences and tips do you have, especially regarding the planning and installation of PLATSA furniture in sloped ceilings? I look forward to detailed advice or proven methods. Thank you in advance!
jaanda
14 Aug 2019 10:47
For planning IKEA PLATSA furniture for sloped ceilings, I recommend the following structured approach:
- Measure precisely, including the slope offset at multiple height sections to capture the height profile dynamically
- Draw the room profile including the slope, ideally using simple CAD software or graph paper with millimeter (mm) accuracy
- Select PLATSA components based on variable heights and widths, as PLATSA is available in modules 40, 60, or 80 cm (15.7, 23.6, or 31.5 inches) wide
- For mounting on slopes: use special angled brackets and never attach the units to only one wall
- Follow installation instructions carefully and use IKEA’s sturdy mounting kits
- For combined modules, it is advisable to connect them with joining elements to ensure overall stability
Regarding measurements, it is crucial to measure the sloped ceiling at multiple points since it rarely runs perfectly straight. Small deviations require precise planning. Overall, accurate planning saves costly mistakes. This is especially true for custom shelves, as their depth varies depending on the angle.
This way, PLATSA furniture can be optimally adapted to the sloped ceiling, resulting in a stable solution.
Foster63
15 Aug 2019 07:52
jaanda schrieb:
For installation on sloped ceilings: use special angle brackets, never attach to only one wall
I can only confirm this advice. Especially with sloped ceilings, sturdy connections and fastening at two points are essential to balance the loads. I also recommend checking the wall material (e.g., drywall or masonry), as the fixing method can vary significantly depending on the substrate.
Additionally, when planning, you should carefully estimate future storage needs and consider whether doors or open shelves better suit the room design. Sloped ceilings often lend themselves to open solutions to avoid limiting the sense of space.
Small size tolerances can be compensated later with edge protection or custom sanding of wooden components if the furniture cannot be made precisely to size.
KUDAISY
15 Aug 2019 19:34
For better clarity, here is a brief guide on how to optimally install IKEA PLATSA furniture under sloped ceilings:
1. Measuring: Start by measuring the slope of the ceiling at several points (left, center, right) within the desired space, and record the height from the floor at each point. Tip: Use a spirit level to determine a horizontal reference line.
2. Sketching: Plot the measured heights to create a profile view of your sloped ceiling.
3. Planning the modules: Choose PLATSA modules that fit beneath the slope or align perfectly with it. Keep in mind that the PLATSA modular system allows you to stack multiple modules vertically or place them side by side.
4. Custom adjustments: For very narrow areas or angled sections, it is advisable to cut shelves at an angle (mitre cut) so they fit precisely.
5. Fixing: Use the included wall fasteners and reinforce them with additional brackets if necessary. For drywall (plasterboard) walls, special wall anchors should be used to safely bear the load.
6. Assembly: Follow the assembly instructions carefully, fasten the modules together securely, and, if needed, cover visible gaps with trim or edge profiles.
Common mistakes include not accounting for the irregular slope, which leads to gaps or instability. Another typical error is neglecting wall fixing—without proper securing, the furniture may wobble or become damaged.
I hope this summary helps with your planning!
boelnu
16 Aug 2019 11:16
I had a similar experience when I wanted to furnish my sloped ceilings. Here’s a bit of my experience to encourage you:
At first, I was worried whether the furniture would fit in the end and if I could secure everything firmly. What helped me a lot was frequently measuring along the slope with a long straightedge, so I knew exactly where the tight spots were.
KUDAISY schrieb:
Make sure to follow the assembly instructions, screw the modules together, and if needed, cover visible gaps with trim or edge profiles.
That’s exactly what I did. Small visual unevenness can easily occur. Trim really helps here to keep things looking neat.
Another thing that encouraged me: it doesn’t have to look perfect – some custom fitting is normal with sloped ceilings anyway. But if you secure the furniture properly, it feels really good in the end. If you have difficulties during assembly, it’s worth asking friends or an experienced helper for assistance, especially with modules that are taller and heavier.
I wish you the best of luck!
LEVI41
17 Aug 2019 09:49
Teo-je51 schrieb:
How do I best measure the slope and take typical deviations into account?
Accurate measurements are essential for installation. I recommend the following approach:
- Measure the height of the roof slope at several points, approximately 30 to 50 cm (12 to 20 inches) apart, as the slope often varies slightly.
- Mark each measurement point on the wall or floor to create a height profile.
- Allow a small margin of 2-3 cm (1 to 1 1/4 inches) in the measurements to compensate for tolerances during installation.
Foster63 schrieb:
I also recommend checking the wall material (e.g., drywall or masonry), since the fixing method can vary significantly depending on the material.
Exactly – the type of wall should dictate the fastening method. Heavy-duty anchors are required for masonry walls when mounting heavy furniture, while specific cavity anchors are needed for drywall.
One final tip: if the slope is very irregular, you can use flexible insulation strips or foam as a spacer under furniture modules to ensure a level base.
